my tahoe used to get the "shivers" at low idle and it would dip at times so I cleaned out the throttle body spacer with some brake cleaner and it hasn't had the problem since.
its all the carbon deposits and build ups that clog it up from the unburned gas
Wouldnt be thehoe92 without teh purple
Lucas Fuel System Cleaner!! I love this stuff.
http://www.lucasoil.com/
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
yes sir i even got free chevy racing key chain wit the purchase, back to op how long has it been doing it. and if it after it warms up could be a misfire or the carbon build up.
I know a lil about everything so dont call me Mr. Know it All.
If you recently got an oil change it could be too much oil pressure :) My brother came home from an oil change like why the fuck is my car shaking so much at low rpms and he had 3 quarts too much oil...
Maybe a month or 2 max.
My Official Feedback Thread
PSN - tech2332
Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
Actually sounds like a vaccum leak too, but like the guy above said, your warrenty should still be intact.
**EDIT** try this, I have an issue with my 02 tahoe (same engine family as yours as long as you have a V8) Look at the drivers side back portion of the valve cover, there is a rubber grommet that that PCV valve goes into, see if it popped out (mine does all the time) and you will have a vacuum leak
Naw it's a 4.3L V6. (Tryin to save gas)
if u still under warranty take it in if not pm me and i can give u a few trouble shooting things to do. what side of houston u on?
Thanks, First Imma try the that Fuel System Cleaner and if it still persists then I'll PM you. Thanks for the help.
Edited by tech2332
PSN - tech2332
  • Who's Online   0 Members, 0 Anonymous, 855 Guests (See full list)
