I was if anyone has used a crunch amp. I was thinking of getting the crunch 1500 watt ground pounder, for my 2 12in re sr subs. Or does anyone have suggestion on a amp.
My girlfriend has that amp in her durango. its running 2 15" RE se subs very nicely. they need more power but for now its fine. i think its 750rms x1 @ 2 ohms. you need to run it at 1 ohm if you can.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
The 1500 does 750x1@1-ohm (they only do half what the box says, except for the 3000). At 2 ohms, it does 375x1.
http://www.stevemeadedesigns.com/board/ind...st&p=733581
Read this^^^
Edited by 1992Chevy K1500
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
The 1500 does 750x1@1-ohm (they only do half wht the box says, except for the 3000). At 2 ohms, it does 375x1.
that sounds about right. the SRX can handle 300 a piece. so i dunno about the original SR's. but what coils do you have on the SR's? because they come in both D2 and D4 coils.
Read this^^^
are you sure? these are the specs online. & what it says on the box. its in my garage so I went & checked before I made my reply.
Peak (Dynamic) Power Rating:
4 ohms: 375 watts x 1 chan.
2 ohms: 750 watts x 1 chan.
1 ohms: 1500 watts x 1 chan.
Max power output: 1500 watts x 1 chan.
Current System:
Pioneer 6900 HU
Bass:
^^Those specs are max. RMS on these amps is half what the max is.
Crunch Ground Pounder V-Drive Amps
All ratings are MAXX. RMS is approximately half of the listed power as has always been the case with Ground Pounder. (other than the GP3000D-Pro)
15.4" widescreen
What it does:
anytime you see those 2 words, either seperate or together, it means Peak. half that and you get close to real specs.
oh, i see what your saying. so what the hell? that means the 15's I have that amp on are seeing 375 each? IF its @ 14.4 volts w/ a 6 volt signal. so its probably high 200's?
Current System:
Pioneer 6900 HU
Bass:
