Souldrop Posted September 9, 2009 Report Posted September 9, 2009 Are there any disadvantages to placing an amp closer to the battery rather than the subs? I've been told and have seen examples of longer power and ground wires taking away from a amp's performance because of the added resistance?...my real question is whether the length of the speaker wire does this as well? Thanks in advance. 1997 Lexus ES300 HU - Pioneer MVH 7350 Processor - Helix DSP Front Stage - JBL P660C Mid/high amp - Alpine PDX-F4 Subs - 1 IA Death Penalty 12 Sub Amp - Cactus Sounds PF300.1
CaptainzPlanetz Posted September 9, 2009 Report Posted September 9, 2009 Are there any disadvantages to placing an amp closer to the battery rather than the subs? I've been told and have seen examples of longer power and ground wires taking away from a amp's performance because of the added resistance?...my real question is whether the length of the speaker wire does this as well? Thanks in advance. Unless its real long you probably wont notice a difference(if you use the proper guage for the length ran). Also if I am worried about the power run not suppling the power I need, I would either up the wire, add a battery to the trunk or both. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
evolution.vc Posted September 9, 2009 Report Posted September 9, 2009 From my understanding as long as you use the proper guage then there should be no problem.
Souldrop Posted September 9, 2009 Author Report Posted September 9, 2009 Cool, thanks for the advice/answer to my question...reason I asked was I was short a few feet on the power wire on my mids and highs amp and had to make up the distance with the speaker wire. 1997 Lexus ES300 HU - Pioneer MVH 7350 Processor - Helix DSP Front Stage - JBL P660C Mid/high amp - Alpine PDX-F4 Subs - 1 IA Death Penalty 12 Sub Amp - Cactus Sounds PF300.1
Boon Posted September 9, 2009 Report Posted September 9, 2009 Technically you're better to have the amp right beside the battery and some long-ass speaker wire High current low voltage vs low current high voltage... 10.x volts fo' life!
