davewms9605 Posted September 10, 2009 Report Posted September 10, 2009 Question.. Im learning cool stuff off here everyday and was wondering...I see alot of ppl including me, do the big 3 in 0-ga wire. My buddy wants to do his but his amps wont take 0-ga wire. He has a Crunch P1500.1 and a Crunch P900.4 and the biggest they will take is a 4 gauge. Does he have to do the "3" in 0-ga or can he do it with 4-ga. Also hes running a stock alt and a stock bat and wants to get a 2nd bat for the rear but hes on a strict budget. Can he use a standard bat for rear? Or can he mix and match (wet-front, dry back)? Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!!
tehbert0 Posted September 10, 2009 Report Posted September 10, 2009 any bigger than stock would help. some people even use 2/0 and bigger for their big 3 Quote http://motorcitydesignsaudio.com
davewms9605 Posted September 10, 2009 Author Report Posted September 10, 2009 any bigger than stock would help. some people even use 2/0 and bigger for their big 3 Yeah, i understand that, but if his amps wont take nothing bigger than 4 ga, how can he upgrade? His stock wire is 4-ga too. He has a 1999 Olds Intrigue Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!!
tehbert0 Posted September 10, 2009 Report Posted September 10, 2009 have him get 10 feet of 0/1 for his big 3. the amps have nothing to do with it Quote http://motorcitydesignsaudio.com
Red-navi-916 Posted September 10, 2009 Report Posted September 10, 2009 u can get the converter thing... from 0gague to 4 i believe but 1/0 is fine in the big 3 Quote BUILDLOG http://www.stevemeadedesigns.com/board/ind...showtopic=61862 "98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!! Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
davewms9605 Posted September 10, 2009 Author Report Posted September 10, 2009 Ok thanks fellas on the big "3" it can get confusing sometimes. Well, i still need to find out the bat question. Can he mix and match bats? (wet-front, dry-back)? He has a regular bat up front and wants a second for rear, hes not putting a huge system just a crunch P1500.1. hes on a tight budget, like $50-$100 Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!!
tehbert0 Posted September 10, 2009 Report Posted September 10, 2009 yeah if he puts a deep cycle in the back he'll be fine Quote http://motorcitydesignsaudio.com
davewms9605 Posted September 10, 2009 Author Report Posted September 10, 2009 Thanks for the great help. I loovvveee this site!!! I ll let him know!!! Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!!
eliassami5 Posted September 10, 2009 Report Posted September 10, 2009 (edited) the wire size that your amp accepts has nothing to do with the "big 3". The goal is to reduce the run of wire while also increasing the wire size in the engine compartment for better, more efficient electrical flow, which means your alt will be able to recharge your batts more easily and efficiently. Your amps will benefit from this because now there will be more current being supplied to them for a longer period of time with less voltage drop..dosent matter if your amps accepts 12,8,4, or 0 gauge wire. You can mix and match batts but its not recommended. People will say that the liquid cell battery will cause the dry cell to run at a lower voltage then it would if otherwise by itself. I personally run a dry cell in the trunk and a wet under the hood and have had no problems. If you are on a tight budget just pick up a dry cell for the rear and when you can just upgrade the bat under the hood for a dry cell also, preferably the same manufacturer. oh and you can get reducers to be able to fit a 0 gauge wire into an amp that only accepts up to 4 gauge. You dont really need it but if you want to upgrade later on to a bigger amp then might as well just use all 0 gauge wire. heres a link to one http://www.hifisoundconnection.com/Shop/Co...sid/0/SFV/30046 Edited September 10, 2009 by eliassami5 Quote 91' Jeep Cherokee - The Heep Just Empty Every Pocket 96' Volvo 960 - The B◘x [sPL_4_U] HiFonics - Alpine Pioneer - Clarion Infinity - Kicker KnuKonceptz
davewms9605 Posted September 10, 2009 Author Report Posted September 10, 2009 the wire size that your amp accepts has nothing to do with the "big 3". The goal is to reduce the run of wire while also increasing the wire size in the engine compartment for better, more efficient electrical flow, which means your alt will be able to recharge your batts more easily and efficiently. Your amps will benefit from this because now there will be more current being supplied to them for a longer period of time with less voltage drop..dosent matter if your amps accepts 12,8,4, or 0 gauge wire.You can mix and match batts but its not recommended. People will say that the liquid cell battery will cause the dry cell to run at a lower voltage then it would if otherwise by itself. I personally run a dry cell in the trunk and a wet under the hood and have had no problems. If you are on a tight budget just pick up a dry cell for the rear and when you can just upgrade the bat under the hood for a dry cell also, preferably the same manufacturer. oh and you can get reducers to be able to fit a 0 gauge wire into an amp that only accepts up to 4 gauge. You dont really need it but if you want to upgrade later on to a bigger amp then might as well just use all 0 gauge wire. heres a link to one http://www.hifisoundconnection.com/Shop/Co...sid/0/SFV/30046 Now thats great information!!!Thanks alot... Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!!
