Thats am amplifier and EQ.
Im sure you can call Pyramid and get a schematic of what the wires are. If you have a better pic of the wiring i can tell you.
I would keep it and use it for small speakers like 6.5 and smaller.
Dom
Yes I'm blind I didn't see the black wire but that's your ground
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
all i need is to get it hooked up ive got highs and mids only,heck i got it free lol
Red and black wire out the left side (back view) should be power and ground,
the paired green and white wires should be + and - input from your headunit
the wires on the right should be to the 4 speakers that the amp is capable of pushing (although it is a 2 channel). just look for matching color pairs, stripes or writing on the sides of one of each pair should indicate the - of that pair.
Edit: don't see a remote wire so you're gonna wanna hook the power wire (red) up to a switched output. Use a test light or DMM to check current through whatever wire/fuse you decide to splice into to make sure it goes off with your key.
Edited by sanitarium
ok this is the way i did it
but if i push the power button in it wont play but if i push it again it plays off the radio but i cant adjust the eq box.
Sounds like the previous user/owner did you a favor and blew it up for ya.
It sucks that you couldn't experiment with it and all , but in all seriousness, if you're serious about car audio...
(you're here so we assume you are!)
Then you're gonna want a good HU, real amps, and if necessary a good eq meant to go in line with preamp signals ( RCAs)
ha yeah i dnt need the eq yet that i know of my HU gots one i figured it mite sound better but finally found my friends and there like DAM thats old school lol keep it.
