XS Power
I will be running 2 Atomic 5000.1's..I will have a Mechman 250 Rhino powering just my back battries...Will 4 D3100'S be able to keep up.Will have 3 run's of 1/0 from the alt to the back???
boyd4.jpg?t=1269745309
Dual DC Power 270XP's
One XS Power S3400
Four XS Power D3100's
Soundigital 12kd
Four DC Audio 15XL's
Atomic 504
Kicker Mid's and High's
One SoftTop Jeep Wrangler
TNESPL-152.5
DB DRAG-153.2
ON THE ROAD TO "55"
Wow,helpful bunch... :search:
One XS Power S3400
Soundigital 12kd
Atomic 504
TNESPL-152.5
DB DRAG-153.2
ON THE ROAD TO "55"
Im no expert but I will try and help. First, more info. Im just assuming that your running both amps at 1ohm. Also are you running anymore amps for your mids and highs? Battery wise I think you would be OK but for 10,000+ watts I think your going to need another alternator or 2 unless your are just burping the system. Running that many watts continuously will drain that system quickly.
I was recommended to install a 170-180 amp idle /270 amp running alternator just for my 3000 - 3500 setup. Thats for daily driving. Im putting a D3100 in the front and 3 Batcap 800's in the back with a dual run of 1/0 pos and neg.
Yes, 4 D3100's will be enough. I would recommend also using a D3400 under the hood, and adding more alt power if you want to keep your voltage in the 14V range.
XS POWER Batteries, Chargers & Accessories
888-4XS-POWER
  • Who's Online   1 Member, 0 Anonymous, 2771 Guests (See full list)
