bassmachine Posted April 16, 2007 Report Posted April 16, 2007 I got 1 problem, I drive a 96 camry and I want to put optima yellow top to start it but connection wire are not on the same side so I turn it around and my post are 2 short,What would you recommend for this. Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
philip Posted April 17, 2007 Report Posted April 17, 2007 I got 1 problem, I drive a 96 camry and I want to put optima yellow top to start it but connection wire are not on the same side so I turn it around and my post are 2 short,What would you recommend for this. had the same prob here...... after trying and trying. i returned it and got a red b/c they didn't have the right yellw in stock. you could actually elongate the grounds and the main power harness, but why go through the trouble.
bassmachine Posted April 17, 2007 Author Report Posted April 17, 2007 The hell wit dat I dont even know what "elongate" means. Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
philip Posted April 17, 2007 Report Posted April 17, 2007 The hell wit dat I dont even know what "elongate" means. make the wires longer. the two grounds on the neg. should be easy but doing the pos. might be kinda hard. if you can't and don't return the battery, now is a good time for the big 3. you probably gonna need a new terminals too.
bassmachine Posted April 17, 2007 Author Report Posted April 17, 2007 Replace it with 8 gauge wire. Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
philip Posted April 17, 2007 Report Posted April 17, 2007 you canif you want,but i used 1/0 in my matrix, for the grounds and added an extra 4 ga to my alt.
bassmachine Posted April 17, 2007 Author Report Posted April 17, 2007 Im going 1/0 gauge fot my alt.Thanks for the tip patna Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
