ok im having problems with my car starting everyonce in a while ill go out to start my car and it wont start it wont turn over it wont make any noise ill wait a few minutes and it will start again i replaced the battery and the starter but it still continues to not start everyonce in a while i need some help figureing out the problem if anybody can help since im not to good with engines oh and its a 99 monte carlo with the 3.8 if that helps
Do you get any dash lights when you try to start it? Like any power?
2 Infinity Reference 1252w 12s
4.2 cubic foot box tuned to 28hz
Sub amp: 1 Profile AP1200
Speaker amp: 1 Sony Xplod XM-504z
Kenwood eXcelon KDC-X492
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
f05112e8-c6ca-4f78-9a8d-47be99303c8b_zps
Diamonds are forever, but 9's end that shit fast....
check the terminals that have the power wire and ground wire on them that hook up to the battery. you can take a wire brush or some sandpaper and sand off the inside part to expose some new metal.
could be your distribution block i had that kind of a problem once. check all the wires around there and make sure theres no short.
'04 Ford Explorer
Jenson headunit
Rockford Fosgate Power T-1000-4
Rockford Fosgate T-1000-1bd
2 Fi 15" ssds
4 Pioneer TS-D6802R
X2 thats what I was getting at. I had that ^ problem about a month ago.
Edit: Yea it could be the dizzy.
Edited by brsteinbach
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
if you have power, your alt and battery is fine, clean connection at the starter, or may be a battery cable going out, so you can change positive and negative, relatively cheap and easy fix.
Behind every great man....is an underwear tag!
