SX650.1... help with settings
hey i was wondering how you sx owners have your amp setup... ive got the sx650.1 powering 4 re8's in a seald enclosure in my tacoma... anyways this digital shit is confusing as hell.... i want good clean accurate power... and im just not sure how to set it... the gain is no problem... its the kompressor, boost/cut, eq stuff... along with the frequency and slope on the settings that have it.... im just not sure how to set it... it sounds like poo and seems like the power is really sloppy the way it is tuned now..(got it from sablenave :shot: ) if you guys can give me some help id appreciat it very much!
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
bump... anybody with sx experience?
3 Kinetik Hc2000's
Dual 200amp alts.
bump again
3 Kinetik Hc2000's
Dual 200amp alts.
thanks for your response polecat... i think ive finally got them understood... now im haveing problems with the amp..... it keeps going into protect and it says low votage on the screen... but the voltage never drops below 13.8 and the last two times it cut out, the voltage was at 14.4v.... i thought perhaps it was my ground wire so i redid it.. and still no change... so im getting kinda fed up with this amp
3 Kinetik Hc2000's
Dual 200amp alts.
  • 1 month later...
does it read 13.8 when your hammering the system? Running it at 2 ohm?
sory its been awhile... yeah ive never even seen the voltage drop below 13 volts... it hasnt been doing it as much lately... but it has done it a couple times... it likes to do it while im playing some old skool metal... no problems with rap or bass testers... i got a new ethernet cable for the connection between the amp and sxrc and it helped quite a bit...im wondering if the prongs for the cable in the amp need bent up a little bit.... and im also wondering just how accurate that built in voltmeter really is...
3 Kinetik Hc2000's
Dual 200amp alts.
  • Who's Online   0 Members, 0 Anonymous, 1102 Guests (See full list)
