2 Kole Audio 5500 watt amps & 2 12 Alphasonik Mayhem
lookin to spend $2k
oh yes, we can get you some way better equipment with that.
how is your electrical? stock battery, stock alt, big 3?
do you want 12's, 10's, a 18? how big and how many subs you want?
how many watts do you want? if you go over 1200 rms or so you're gonna want to budget for a better battery or possibly a second battery.
etc, etc, etc.
give us some ideas of what you want out of your system.
i would say 15's but at the same time, it might be more effective to do 2 12's since you could get the proper airspace for them.
its usually pretty hard to make room for 2 15's with the proper space in a trunk.
what are the dimensions or your trunk (height, width, depth) so we can figure up how much airspace you can get.
your electrical looks decent but with 4000 rms you will want to add a couple more hc800's.
how many amps is your stock alt btw?
just off of some raw math you have about 11 cubic feet with those dimensions.
with box, port, subs, and keeping the subs away from the walls i would say about 9 useable cubic feet.
so you have enough for 2 15's and you're stock alt will be fine but you will want extra batteries for sure and should think about upgrading the alt later down the road.
since Audioque is a good budget brand and you will need batteries i would say this is a good start for ideas for you:
2 15" HDC3's and a AQ 3500D for about 1200 dollars and then the rest could be put towards batteries, wires, box building.
heres a link to audioque
http://www.audioque.com/aq/AQ3500D.htm
http://www.audioque.com/aq/HDCSeries.htm
I just bought a Kole 5500D amp. This thing it a best. Haha think it is way too big for what I need. .
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
  • Who's Online   0 Members, 0 Anonymous, 1257 Guests (See full list)
