darren509 Posted September 29, 2009 Report Share Posted September 29, 2009 Kole Audio 5500 watt amp specs: RMS Power Rating: 4 ohms: 1700 watts x 1 chan. 2 ohms: 2500 watts x 1 chan. 1 ohm: 3200 watts x 1 chan. Max power output: 5500 watts x 1 chan. Regulated PWM Power Supply Wired remote bass level control included. LED power indicators Bass Boost: 0-18 dB at 45 Hz Midnight blue anodized finish with silver end caps High-speed digital circuitry Three-way protection circuitry (short, thermal and overload) Bridged synchronization (strap amps together for double power!) Pre-amp outputs 1800 Phase switch Variable low-pass filter (40-200 Hz, 12 dB/octave) Variable subsonic filter (12 dB at 20-50 Hz) Frequency response: 15-150 Hz Low Level Inputs: 200mV-6V Dimensions: 20-1/2L x 10W x 2-1/4H 1/0-gauge power and ground wiring is required for installation. Alphasonik PSW912 specs: Sensitivity: 95 dB RMS Power Range : 2200 Watts Impedance: Dual 2 Ohm Dual Ohm Subwoofer Cast Aluminum Machine Cut Alpha Basket Motor Assembly Heat Sink Ultra Light 2-Layer Carbon Fiber, Kevlar Cone with Aluminum Dust Cap TLTF J-Surround Flat Progressive Rate Nomex Damper with Spiral-Woven Leads 8-Gauge Lug-Lock Input & Output Terminals Rated at 2200 Watts RMS 93dB Efficiency Frequency Response of 45Hz to 900Hz 200 oz. Triple-Stacked Magnet Dual 2-ohm 3" Voice Coils Link to comment Share on other sites More sharing options...
brewer_brewer Posted September 29, 2009 Report Share Posted September 29, 2009 what is the point of this thread. are you just sharing specs on what you have or trying to sell these? REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt" Link to comment Share on other sites More sharing options...
enemyofsilence Posted September 29, 2009 Report Share Posted September 29, 2009 ^ or are you looking into buying these? Team Bass-Hz Link to comment Share on other sites More sharing options...
enemyofsilence Posted September 29, 2009 Report Share Posted September 29, 2009 edit: double post fail Team Bass-Hz Link to comment Share on other sites More sharing options...
Guest Cobrastang98 Posted September 29, 2009 Report Share Posted September 29, 2009 Most confusing/pointless thread of the day. Link to comment Share on other sites More sharing options...
darren509 Posted September 29, 2009 Author Report Share Posted September 29, 2009 im interested in buying and lookin for feedback before buying Link to comment Share on other sites More sharing options...
brewer_brewer Posted September 29, 2009 Report Share Posted September 29, 2009 oh....ok. now i get it. lol. how much are you willing to spend on this system? i think we can get you some better equipment for the money you would spend on that stuff. REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt" Link to comment Share on other sites More sharing options...
Guest Cobrastang98 Posted September 29, 2009 Report Share Posted September 29, 2009 ^^^ Would have helped out your cause to possibly mention that in the first post. But I wouldn't get those amps or subs... Better products can be bought for cheaper without a doubt. What were you planning on spending on this?? Link to comment Share on other sites More sharing options...
barros57 Posted September 29, 2009 Report Share Posted September 29, 2009 Im also looking at buying a kole 5500 amp. And an orion HCCA sub. Does anyone else have this amp. How do you like it? My 93 chevy truck Orion HCCA 15's Build 6K HID's 2 orion HCCA 15.4 2 AP30001D's 2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp Rockford p200-2 Rockford p200-2 Rockford p300-1 Kole KX1 5500D -broken Link to comment Share on other sites More sharing options...
brewer_brewer Posted September 29, 2009 Report Share Posted September 29, 2009 ^^^ Would have helped out your cause to possibly mention that in the first post. But I wouldn't get those amps or subs... Better products can be bought for cheaper without a doubt. What were you planning on spending on this?? damn man. almost identical to my post. but i beat you by a couple seconds. REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt" Link to comment Share on other sites More sharing options...
