Ive got a set of 55w HID's on the way. Right now when i play my system full tilt at idle my voltage drops low...like low 11's. Will i have issues with the HIDs? Just curious...
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
why is your voltage that low? lower the volume bro.
but it shouldnt affect anything. HID's stay pretty constant from what i hear
you might need a relay harness anyways stock harness might not support the 50w
ballast depending on vehicle. but if your voltage is dropping to low 11's then they too will have light dimming to them
even with a relay harness
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
My alty puts out the power around 8-900rpm. engine idles at 600. Umm...i ordered the wire harness but i just wanna make sure theyre going to be ok if the voltage happens to drop.
Systemless.
you should upgrade your electrical man.
but the hid's won't dim like your halogen do. they might still dim a little though if you are dropping into the 11's.
they will use less power and be brighter though.
