took it out of the truck to see what it would sound like inside a house, got some rattling with it lol
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
Awesome. Sounds really good. Can't believe how much that things moving.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
yep one of tang bands high ex subs. the quality in how they are made is great, well put together, has decent cooling feature for the sub, cone is nice, large voice coil, and only at $30 a sub, u cant go wrong with one for testing purposes
1 3500d AQ amp
That was cool!!!
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
AudioControl Epicenter
US Amps AX2000
US Amps MD-43
1 set Alpine type X components
1 set RF Power components
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
Kinetic HC-600 (Back)
Second Skin Damplifier Pro
i will be mking a t-line tmorrow for one of these. just got it today =)
mine will be pvc pipe tho. so i can twist and mold it to my room
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Cool Stuff!
Yeah, I think www.partsexpress.com has those right now for $33 each!
I have that same speaker- one in each of my doors, but they are on active high pass right now. Maybe I put them back to the bass. People see them and are like: "You are going to blow that little speaker..." ...nope, don't think so. Really tight speaker, especially when you put it into the right box for the right application as you have sir. :) Good work!
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Cool Stuff!
thanks man, i plan on doing a t-line with 4 of them and see how it sounds. should be cool considering nobody would dream it would be 5'' subs making the bass in my truck. more of scratch your head factor lol. plus it keeps cost down for right now, seeing how money is tight
1 3500d AQ amp
