This is how it sits on the car, and matches the fenders pretty nice.
Posted Image
Posted Image
Posted Image
Posted Image
Next thing to do is to flatten the top of the bumper, cause now you can surf on the waves...
First making a little plate of 3mm thick against the hood and the 2 pieces the come under the lights.
So we will have 3mm of difference everywhere at the top
And when this is done, I get it back off and flatten it with the sanding block.
The next day... with some metallica on the background, but the sanding block with a grain <img src='http://www.stevemeadedesigns.com/board/public/style_emoticons/NEW/mega_shok.gif' class='bbc_emoticon' alt='80' /> and rubbed some bumper.
First thing that came to light is that there's a big layer of gelcoat on there, witch is good in this case.
After a couple of hours with the block, most of the unevennesses are already gone, and it all looked so much better.
Then I started with connecting it all nicely on the car.
this was easy. Sawed 3 little MDF-plates of 4mm thick.
2 for L & R under the headlights, and one for under the hood.
Just taped it on with doublelayer tape
Posted Image
Posted Image
Cause the hood has a bit of a rounding, I disced the plate a little, so it goes nice with the flow.
Posted Image
After that, mounted the bumper, and put some filler on there.
Posted Image
Posted Image
Posted Image
Now, I have to maintain this height, and work towards the front of the bumper. EASY
O yeah, I also reinforced some pieces at the back of that thing, much better if you have to rubb it all.
Also did a phonecall to the people who delivered me this piece of crap.
Friendly asked to put my money for those carbon splitters back on my account, I'll make those myself...Then we're sure it'll fit..
About all the rest, better to shut up before I get the rest of my euro's back on my account. Then it's time for some puppetshow
The connection on the top of the bumper is OK, this fits now how I wanted it.
Then I started to make a notch on top of the bumper, where the hood falls into.
That something you have to put some extra time in, to make this perfect.
So, mounted back the bumper, and where that notch has to come, we taped it all with tape.
Mesured it all correctly and penciled it on the car. After that, pulled the tape and cut it out.
Now this is my model.
Posted Image
made another plate MDF of 4mm thick
Posted Image
Taped this on the bumper with doublesided tape.
Posted Image
Posted Image
Once this was done, I put some filler towards it.
Posted Image
Rubbed it all down till it fitted to the plate nicely.
Posted Image
Pulled the plate from it, and this was the result.
Posted Image
Posted Image
then it was childsplay to connect the sideds perfectly.
Posted Image
Cause on the inside, I now had a right upside,I rounded this like it is done on the original bumper
For this, I used white filler instead of black one, so I could see much better if it was all straight in line with everything.
Posted Image
Posted Image
Then I also discovered.......the bottom of the bumper was also tilt and crom. aaaaaarg
Anyway, to make this perfect, you have to have a 100% straight table (wich hI had.
Put the bumper on there, and drew it over.
After that, taped the table.
Now you can see how miserable it looked.
Posted Image
Posted Image
Posted Image
Also put a pile of filler on the side, and put the bumper nicely on the table.
Posted Image
Posted Image
Posted Image
Here you can see the result of the trick of the table
Posted Image
A perfectly STRAIGHT bumper
life can be beautiful
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
These are going to be the 2 CF splitters.
Thought about making them in 1 piece, but stepped away from that idea.
The splitters I going to make, will look a bit different then the original. On the inside, there going to flow out a bit further. You'll see what we mean further on.
This is what he uses as base.
The aim is now that we put some layers of fiberglass polyester at the bottom.
Posted Image
Posted Image
The reason why I made this twice, is because I were afraid that he couldn't get to the inside that good.
Posted Image
One of the main problems of this big bumper project was the license plate.
What I didn't want for sure is a big plate would come before the middle whole of the bumper.
The plate we're going to make for the license plate will be 28*8cm
This plate of fiberglass of 4mm thick, will be my plate. You can see that this plate has the same rounding then the bumper. So lets cut 28*8 out of it.
Once I has this, I puts the piece back on the bumper and pull with some filler the edges nice around the plate. So we will get an original and fine finish of the license plate
What the cops will say... I DON'T CARE !!
Posted Image
Posted Image
Used some more fiberglass clothing for the bottom of the carbon splitters.
Made them big enough, so I could get the disc into that and see what will be a nice splitter.
Posted Image
Posted Image
You see here I got much more material on the inside, so I going to let the splitters flow much more further then they are originally.
Posted Image
This will be the license plate holder eventually.
Posted Image
Put some little screws on the back, so I can secure it from behind, and I doesn't have visible screws at the front.
Posted Image
Where the plate will be, I painted the bumper in black.
Posted Image
If I puts the grey plate on there, it's more obvious to see if the plate is hanging leveled.
I hate it if a license plate is hanging tilt.
Here you can see how I planted the plateholder onto the bumper.
Posted Image
Posted Image
Posted Image
Worked some more on the splitters.
The model will stay like this, but there's a little more difference, tomorrow we sort that out.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
As you can see, I made them a bit longer, towards the middle.
Posted Image
This oilcooler is going into the center piece of the bumper.
When I bought the car 2 years ago, this was one thing (of the many) I had to have for sure.
That there will be lovers & haters, works just fine for me.
Posted Image
Posted Image
Here you see that I spread the fabric nicely, to get a nice connection.
Posted Image
Added a layer of polyester/fiberglass
Posted Image
Once removed, I edited the upside immediately with the disc.
I grinded the top from in between.
Then I put in between, a piece of aluminium 2mm thick. Now it’s all strong enough.
Posted Image
Here it’s all grinded properly.
Posted Image
Posted Image
These 2 pieces of MDF I made First.
They will be the front of the hole.
In the lower hole, will be the oilcooler, and the slot if just an airslot.
Posted Image
Posted Image
Posted Image
Then I started to rubb the fiberglass piece so it fitted nicely into the bumper.
That’s not so hard. You just pull a line with a pen on tape, then you push the piece into it, and once it’s dry, you have the same line on your filler.
Then it all comes to rubbing it just towards the line. SIMPLE
Posted Image
Posted Image
This is the result of the fiberglass piece, and it will be covered in carbon
Posted Image
Posted Image
Then I bought a piece of aluminum of 15mm thick
Posted Image
Posted Image
O yeah, almost forgot, had a large block of aluminum lying aroud the place, 15mm thick.
First I covered it with my mold I, that is made of MDF wood, and drew out what to remove.
I sawed it out with the line saw. I’ve done a lot in my live, but there are many cooler things to do then this, pfff
Posted Image
Once this was done, it was time for precision work.
Here you can see 2 fine rubber O-rings laying next to the copy-cutter.
First I put on the thick ring, so I couldn’t cut too much out.
Posted Image
Here you can see better what I mean with that O-ring.
You can see clearly there’s about 1.5mm of material away from the mold.
Also you see that the cutter had here best time, time for a new one…look at those slaches.
You also see that in the lines of the aluminum.
Posted Image
This done, put on the smaller, finer O-ring, and did it all again.
Now it was till 0.5mm perfect.
Mounted a new cutter, who attend to tidy it all, and by using lots of WD40 I got a nice finish and result.
Posted Image
At this picture, you really can see the difference.
Posted Image
Here, the piece still with the MDF mold taped on it.
Posted Image
Then, I rounded the outer sides.
Harnessed the cutter, and did all that had to be done
Posted Image
Posted Image
Once this was done, the “dangereous” work turned out well, and I thank jesus fort hat
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
