You also can see I bended some white alu plate.
I took this specially so be stick-vilt, where the piece is getting into, sticks good.
The upper plate of the remote controle will become 1 with the alu.
Posted Image
Posted Image
Better look on everything
Posted Image
Posted Image
This is how it will appear
Posted Image
Posted Image
There will be a lot of work to it, but we think it all pay of...
IF IT WORKS
remote control.
Posted Image
Posted Image
In the alu piece where I made this, I made an extra plate on the bottomside, fastened with one tiny screw.
like this, I can always get into the inside, and he can changes the batterie from time to time.
Posted Image
Posted Image
Posted Image
Posted Image
Here you can see where the remote control will slide into. As you can see, I put some selfclitting vilt on the sides, and the bottom.
Did this to make sure it all glides nicely...
Posted Image
Posted Image
You see the slot in the middle.
backside, tightened with that screw.
Posted Image
This alu plate lays on top, and is tightened with little screws. If there would be a problem, it's not hard to get into it all.
Posted Image
On the bottomside, you see I made something simple where he can get into with the finger, to glide it all out.
Posted Image
Posted Image
The thing in the car.
Posted Image
It'll be super easy to control the radio. Nothin' will feel stodgy while riding the car.
Posted Image
All of this has to go in primer.
After that the console is going in satin-black, like he original was. the remote will be sprayed in the same silver as the rest (trims, ...)
The remote got it's color.
It also got a nice contract with the Alpine buttons.
Posted Image
Posted Image
Posted Image
One thing to do still, is to paint the little screw (where it's tightened with) in silver.
Posted Image
This would be the innerview of the armrest.
This will be the new coverplate that'll come above the remote control.
I made little heights. (do not understimate the time that goes into this, it's a ****ed up job)
Posted Image
Posted Image
On the left,you can see the Nokia mobile phone. Took this one for takin' pictures.
On the right, you see a IRIVER MP4 player.I can attach this on the radio, and watch movies en pictures on it.
I normally doesn't buy this stuff, but it will look pretty cool...
Gotta help belgium economy.
Posted Image
They'll be worked in on the alu plate like this
Posted Image
Posted Image
On the front of these toys, I made a little ditch, so you can get the things with your finger
Don't mind the dust.
Posted Image
this silver box will be under the mp4 player.
Posted Image
here the ears will be, and a lamp. So this also gets a good space and doesn't lay beneath my feet or something.
The amrest almost finished, and put back in the beemer.
If you see it like this, nothing special...That's the beauty of it.
Posted Image
On the bottom the little grey lip to pull out the remote control.
Posted Image
This is how it looks like when the remote is out. Easy to control now.
The gear is set to D, so can't go further the back.
You can see there's enought place between both things.
Posted Image
Posted Image
Posted Image
Posted Image
I have been thinking things over. I forgot that i still have a set of realy ugly Focal crossover.
Posted Image
Posted Image
At first i wanted to integrate them in an MDF board, but that's not flashy enough.
Now i'm going to integrate then completely so that i can let them come out automaticly. At least i'm going to try...
These are the filters i was talking about.
The white plastic strips will be replaced by black strips.
Posted Image
Posted Image
I can say that this looks much better.
Posted Image
The plexy boards were the filters used to be mounted on are now removed.
I've replaced them with an MDF board wich got an "uppermill treatement'
Posted Image
Posted Image
This board will be mounted on top of the other one
Posted Image
Here you can see them on top of eachother
Posted Image
I made this because i didn't want the speakercables to be visible.
Posted Image
So the cables are guided from one side to another inbetween the 2 boards.
Posted Image
Filters mounted...
Posted Image
Posted Image
Posted Image
Posted Image
Here you can see that i have enough space between the board for the wires.
Posted Image
Posted Image
On this picture you can see the tray while it is closing. The hightec stick you can see will be made out of carbon.
Posted Image
Posted Image
This is what it lookes like when it is fully opened.
Posted Image
Posted Image
Here i show you how far i'm going to allow it to open.
Posted Image
Posted Image
Posted Image
I'm going to cover the crossovercase with a piece of plexy. I usually allway try to use real glass, but because i want this one to bend a bit, i'm forced to use plexy.
I first intended to just order a "ready-made" piece, but instead i'm going to try to bend it myself.
the plexy has a 5mm gauche.
The first test came out pretty good.
I've clamped and than heated it with a hot air paint remover.
This is the result.
Posted Image
I noticed that by heating it, it get's rough.
so i had to sand the irregularity. First with a wet nr 800 sandpaper, then with a nr 1200, to end with a nr 2000. Afterwards i polished the entire piece.
Posted Image
The ends of the plexy piece were pretty deformed, but i was able to fix this.
Posted Image
Then it was time to start on the big piece op plexy wich had to cover the entire crossover case.
This i had to clamp on as much points as possible, bucause i was affraid that it would easely deform because of the heat.
Posted Image
Posted Image
Posted Image
than i heated it nicely so that it would easely bent.
Posted Image
Posted Image
If you don't fixate it firmly, everything will deform for sure. Here you can see that my piece is pretty straight.
Posted Image
Posted Image
Then i started sanding. I started with a nr 1200 to end with a nr 2000.
Posted Image
Posted Image
Afterward i started polishing.
Posted Image
Posted Image
My plexy cover looks great, and has only cost me 7 euro.
  • Who's Online   0 Members, 0 Anonymous, 825 Guests (See full list)
