CR Boom Posted October 5, 2009 Report Share Posted October 5, 2009 off center, they say farther from the port is better.. Quote 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's Link to comment Share on other sites More sharing options...
exxd Posted October 5, 2009 Author Report Share Posted October 5, 2009 off center, they say farther from the port is better.. okay thanks. Quote Link to comment Share on other sites More sharing options...
Boon Posted October 5, 2009 Report Share Posted October 5, 2009 Jesus, 9.3 cubes. Should slam some lows. Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
exxd Posted October 6, 2009 Author Report Share Posted October 6, 2009 (edited) Jesus, 9.3 cubes. Should slam some lows. this is what the manufacturer recommends: BL 18 – Ported box we recommend using 5-10 cubic feet @ 30-37Hz tuning, you can tune a little higher if you wish but we recommend keeping it close to 32hz for a daily driver. Again the same 12-16 square inches of volume applies per cubic foot of volume. and its going in a tahoe. i wanted the box to be almost as wide as my "trunk" area, which is 47". so to have the box be 47", i chose 22" as height and depth to maintain some of those recommendations. edit: i guess i could have also took the mounting depth of the woofer into more consideration when i built the box lol.... mounting depth of the woofer is 9.750”. omg and i used 22" lol... well i wanted to be able to have the box face forward against the cargo hatch or fire upward without having the box demensions be awkward if i turned one way or the other. so 22" either way seemed alright at the time. i hope it sounds good and slams, thats all im really concerned with. but this box has me nervous a little. i used re box calculator and have never built a slot port before. Edited October 6, 2009 by exxd Quote Link to comment Share on other sites More sharing options...
exxd Posted October 6, 2009 Author Report Share Posted October 6, 2009 Jesus, 9.3 cubes. Should slam some lows. do you think it will only be go for lows? or will that much airspace be good for the range of the speaker including the lows? Quote Link to comment Share on other sites More sharing options...
exxd Posted October 6, 2009 Author Report Share Posted October 6, 2009 bump up my post Quote Link to comment Share on other sites More sharing options...
