Hi all,
if any audio junkies out here someones offered me a JBL 1201.1 mono amp and wondering if its powerfull enough to run the dc level 4 15" confortably
please help me before this sells
normally £300 - $500
im getting for £120 - $300
specs of amp
Amplifier Type MONO BASS
Amplifier Class D Class
Full Range Digital Amplifier Yes
Load Capability 4/2Ω Stable
Low pass Filter Yes
High-pass Fliter No
Line out No
Speaker level Input No
Maximum Power Output (4ohm) 1200w
Rated Power Output (4ohm, 14,4V) 1200w
Rated Power Output (2ohm, 14,4V) 1339w
Rated Power Output (1ohm, 14,4V) N/A
Bridged Power Output (4ohm, 14,4V) 1200w
Rated Power Output (4ohm, 12V) 787w
Rated Power Output (2ohm, 12V) 1114w
Rated Power Output (1ohm, 12V) N/A
Rated Power Output (1.3ohm, 12V)
Rated Power Output (.5ohm, 12V)
Low-pass Filter N/A
High-pass Fliter N/A
Input Sensitivity 140mV
Signal to Noise Ratio 70dB
Frequency response (+0dB, -3dB) 10Hz - 302Hz
Dimensions (WxHxD) 18-11/16" x 12-5/16" x 2-3/8"
Price: £299.99
and here website info
CLICKY!
please help asap!
dont wanna find out yeah do it and its sold as really cheap
thanks dan
Dan Plummer - 1x DC sounds Level4 15" - 800wrms - 3.5 cuft Ported Box - Rover 25
Peak= 142.2dB @ 40Hz
40Hz= 142.2dB
33Hz= 139.6dB
25Hz= 136.8dB
20Hz= 136.1dB
hes saying that its not worth it because:
Originally Posted by spudz
Quote:
Originally Posted by vRShafz
ah dual 2 ohm means u can only run the sub at 1ohm or 4 ohm
so amp will only run at 4ohms with that sub (so 787w rms)
to get the max out this amp it would be more suited to a dual 4 ohm amp
how can i get
or
u need a dual 4 ohm sub matey
a dual 2 ohm sub can only run at 1ohm or 4ohm
a dual 4 ohm sub can only be run at 2ohm or 8ohm
so to get the max out of ur sub look for a 1ohm stable amp
HELP CONFUSED
40Hz= 142.2dB
33Hz= 139.6dB
25Hz= 136.8dB
20Hz= 136.1dB
hmmm help me i want to buy but dont wanna end up not getting the most out of it and should of going for sundown 1500d
40Hz= 142.2dB
33Hz= 139.6dB
25Hz= 136.8dB
20Hz= 136.1dB
if your car is running and you have a decent charging system you will get 1200 at 4ohm. 787 is at 12v which is lower then most car batteries rest without the car running.....
CAUTION!
POOR INSTALLATION MAY SHORT BOTH YOUR SYSTEM AND WALLET
got stock parts atm but getting red top battery and then new alternator few months down the line
so do yo reckon should do it?
40Hz= 142.2dB
33Hz= 139.6dB
25Hz= 136.8dB
20Hz= 136.1dB
yea, work em over on the price though, its an older model and would sell for that much brand new with a warrantee
i'm assuming its used, so 200 seems fair so long as its in really good condition
Team DC
so just to clarify with car running (always will be) ill be putting out 1200w to my DC LEVEL 4 15" ported enclosure
ive also offered him £110 ($175) with full shipping as that was extra ($40) and pictures and condition now before payment etc
40Hz= 142.2dB
33Hz= 139.6dB
25Hz= 136.8dB
20Hz= 136.1dB
?????? sorry i dont wanna lose this major interest in it atm
40Hz= 142.2dB
33Hz= 139.6dB
25Hz= 136.8dB
20Hz= 136.1dB
  • Who's Online   0 Members, 0 Anonymous, 1465 Guests (See full list)
