Amplifier decisions HELP!!!!!
So im stuck between a rock and a hard place there's two amps that i really like for my subs
im stuck betwen an Audiopipe AP30001d and a MB quart dsc2000.1D here are the specs
the subs im running are 2 Pioneer Premier TS-W3002D2 or D4 (depending on amplifier) 12's
http://www.sonicelectronix.com/item_16665_...TS-W3002D4.html
Audiopipe AP30001d
Features:
# Audiopipe 3000 Watt Mono Car Amplifier
# 1 0hm load stable
# output power (rms): 1800w@4 ohm or 2x600w,
3000w@2 ohm or 2x950w,
1500x2@1 ohm
# overload protection
# overheat protection
# variable low pass electronic crossover
# variable subsonic filter.
# built-in variable phase shift.
# 55 mm(h) x 176mm(v) x 710mm(l).
# 2.2 inches(h) x 6.9 inches(w) x 30 inches(l).
# distortions: <0.2% thd
# signal to noise ratio: 70db
# input level: 0.2-5v
# bass boost frequency: 30-80hz
# low pass filter: 40-180hz
# subsonic filter: 5-50hz
# frequency response: 8-180hz
MB Quart DSC2000.1D
# Discus Series Class D Monoblock Car Amplifier
# RMS Power Rating:
* 4 ohms: 500 watts x 1 chan.
* 2 ohms: 1000 watts x 1 chan.
* 1 ohm: 2000 watts x 1 chan.
# PWM (Pulse Width Modulated) MOSFET power supply
# Wired remote bass level control included
# LED power and protection indicators
# Tuned Bass EQ (0-9 dB bass boost at 45 Hz)
# Soft start sound
# Preamp RCA outputs
# DC, short, thermal, and overload protection circuitry
# Unbalanced RCA inputs
# Damping Factor: >180
# Variable input level control: 0.2V-0.6V
# Variable low-pass filter (35-250 Hz, 24 dB/octave)
# Subsonic Filter (15-35 Hz)
# Frequency response: 15-250 Hz
# Dimensions: 19.69"L x 9.45"W x 2.7H
and here are the two mids and highs amp im stuck between
mbquart dsc4125
http://www.sonicelectronix.com/item_13496_...t+DSC+4125.html
Audiopipe AQX300.4
http://www.caraudiodeals.com/audiopipe-aqx3004-p-2808.html
Help please i would like to stay with 1 brand
CB7 wit bang
yea remeber the AP is dual mono and its 3000 bridged at 2 ohms so only d2's would work and itll be a bit high on the power if you actually produce 3k
Edited by P4killer_
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
i'ld get the MB Quart setup, they take up less space.
i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
  • Who's Online   0 Members, 0 Anonymous, 1639 Guests (See full list)
