gap diameter inside and outside
spider landing
coil height
space between spider landing and top ot the pole
these are some of the things you need to know about your motor
look here Dave can help you out
Team PSI
Roseville, CA
that psi is cool lot of information. has anyone on here ever tried building their own or is it cheaper just to buy another one
I've built a bunch of frankenwoofers in my past, either for myself or for friends. All depends if u have the ability to build them yourselves or just wanna buy one. There are positives to building "custom" woofers and negatives usually are finding matches(if you want multiples) or running into issues along the way(coils not fitting, basket mounting points don't match up to the motor, etc issues).
It usually is cheaper if you can find the right parts but not by a significant amount for the most part.
Pioneer AVIC-N2
