alternator upgrade question
OK i dont know but my installer says that installing a bigger amp alternator can throw a code in my HOE because of GM'z sensitive CPU.... Is this true or false pls. explain ?
153.3 @ Turkey Drag 2009
Spl Modified 1001-2000 - Derrick Jones my alias... Wudn't accept DEEz NUTz !!!
I think it will do that in most OBDII vehicles, but IIRC if you get a MLA with the alt the codes will go away, and you will have even more voltage.
¿ǝɯɐƃ ǝɥʇ
what the devil is a MLA ? is it the same as the cpu under the dash ?
mla is missing link module.. i have a 15+ daily voltage system in my car.... doesn't throw codes.. it's an obd2 vehicle..... but a toyota... might depend on the manufacture
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
Guest DC Power Rob
Not true at all, unless the wrong alternator is put in there. What year Tahoe is it? Where most people have issues with alternators on GM vehicles is running multiple alternators and piggybacking the excitation circuits which does cause problems because it pulls the voltage on the lamp terminal too low.
As for doing a single upgrade, we have NO issues with codes of any kind, EVER on the GM vehicles. All our voltage regulators are special versions manufactured by the OEM manufacturer for GM and our regulators are built on the same line, in the same factory as theirs to make absolutely sure that we have ZERO compatibility issues ever on these vehicles.. Rob
thanks again Rob for the info. PM sent......
False.
I would ignore your installer on that one.
We have never had any problem running a single alternator in ANY vehicle... Ever.
Mulit setups will pop up a light at times. Nothing you cant remedy, just dont hook it up incorrectly.
We have NASA build our regulators so they work in all atmospheres and conditions.
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
