you shouldnt have to take the system out but you probably should do some electrical upgrades next.. big 3's pretty cheap to do yourself. not that hard either and it will help
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
any electrical upgrades? if your running a t2000 i would definitely do at least the big 3 a new battery up front. maybe one in the back too. thats alot of power for stock electrical to handle regardless of weather or not its causing your check engine lights or airbag light. but im thinkg check engine could be something electrical..
its not the check engine its the check gauges..
and for my electrical i done the BIG 3, have a yellow top front and back. front battery (+) wired to back (+)..and for back battery (-) is grounded to back of my rear seats and sanded off some metal for better contact..
i think i am anyways due all the damage is causing...and since the winter is coming up soon my vents dont work at their fullest..i get a lil bit of air come out..this all happen last week..all at once..WERID SHIT!!..
also i think its time for some repairs because i had this truck for 5 years and i havent had a problem at all..truck worked great.. and i had to do is to change the oil every 3-4 months and thats about it..right now i have around 77+miles.. close to 80 already..so i guess its time to put money into this baby..lol
The airbag light means that one or more of your airbags are no longer connected for whatever reason. Check all the connections to you airbags (might require taking out seats, dash, etc., but a delaership will charge the hell outta you). The check gauges light means that one of more of the gauges are now unreliable for whatever reason (broken, loose, whatever). I'd especially be careful because you speedometer could be damaged.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
