youngmoney2347 Posted October 19, 2009 Report Posted October 19, 2009 watsup can you heklp me with my 4 channel ok every time i start my car my 4 channel goes into protection mode it was working fine today all of a sudden it started to go into protection mode.. can any one tell me what could be the problem
Marlo Stanfield Posted October 19, 2009 Report Posted October 19, 2009 Could have burned up from a number of things causing it to permanently go into protect... Power wire could be grounding itself somewhere between the amp + batt or a number of other things. Really can't help you unless u go into sum more detail about when it first happened. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
youngmoney2347 Posted October 19, 2009 Author Report Posted October 19, 2009 Could have burned up from a number of things causing it to permanently go into protect... Power wire could be grounding itself somewhere between the amp + batt or a number of other things.Really can't help you unless u go into sum more detail about when it first happened. it started while my mom was driving she said it sounded like something was touching she heard a static while she was listening to the radio she said she just turned the deck off when she heard that when i checked it out the amp kept going from green to red every time i stared the car
Djmixmasterkid Posted October 20, 2009 Report Posted October 20, 2009 I had this same prob. Its either bad wires or bad amp. When I had this problem I bought new wires and when I hooked the amp back up it fried. Then I hooked up my old amp and everything was good. I still kinda think it was a little of both for me. If you have another old or cheap amp the try it and see what it does. I know if I ever find out you were messing with my 17yr old daughter, i'm diggin' off in that ass and then your next post will be asking for tips on how to remove my size 12 shoes from your ass. Open Up The Trunk Pioneer P6000Ub H.U. Sundown Saz-1500D Hifonics ZXi 4410 12" Directed SX12D4 (x2) 12" 1500rms Sub x1 Front - Powerbass 4XL-65-92 Mids Rear - Cadence 6.5" Mids Electrical Under Construction Check Me Out(CarAudio Vids) Official Feedback Thread Check Out My Music Page
