Duece22 Posted October 23, 2009 Report Posted October 23, 2009 Hey guys. I have a SAZ-3000d powering 2 15" DC Lvl 4s with lvl 5 coils. I have done the big 3. Im using a 230a alt. I have a huge red top under the hood and 1 optima yellow top in the trunk. Its all 0ga. I was wondering if i could mix batteries and still be fine? Also, how many more batteries would i need to keep my voltage up? Sometimes when im playing a song my voltage will drop to 11.80ish volts or sometimes a little bit lower. Id like to find some good batteries, that arent overly huge but still have a good power output and not so much on the pricey side. I can have pix up for you guys if u all need to see anything in my current set up. 2008 Hummer H3 x2 Sundown Audio Nightshade V2 12s x1 Sundown Audio 3000D
Iraggi Alternator Posted October 23, 2009 Report Posted October 23, 2009 What does your voltage drop to when you rev the motor to 2000 rpm?
Duece22 Posted October 23, 2009 Author Report Posted October 23, 2009 I honestly do think ive ever done that. Ill have to find out. 2008 Hummer H3 x2 Sundown Audio Nightshade V2 12s x1 Sundown Audio 3000D
CaptainzPlanetz Posted October 23, 2009 Report Posted October 23, 2009 What does your voltage drop to when you rev the motor to 2000 rpm? This^^^^^^^^^^^^^^^ You could get an overdrive pulley, and it would increase your idle output. Also for my build I am gonna use Shuriken batteries, they are the same thing as Kinetiks but with a Ninja on the case instead. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
