Yeah look for an IGN fuse.. make sure you put the wire on the side that doesn't get power with the ignition on.. That way your remote wire will be fused. Pull the fuse, turn your ignition on and use a test light or dmm to see which side has power and which one doesn't.. Put it on the side with no power. Then insert the fuse, and you'll be good to go on the switched 12 then.
thanks folks i will try it tonight
