philip Posted July 5, 2007 Report Posted July 5, 2007 which roundover bits you guys use. i have a porter cable router and the bit i use doesn't go back past the plate far enough. in other words if i used the bit with the plate i would end up with a lip and then a rounded edge. i took off the plate to pushed the bit farther back but just wanted to get some opinions ideas and what size roundovers you're all using.
mojoman Posted July 5, 2007 Report Posted July 5, 2007 phillip- you can make a new base plate for you router really easy. i have a porter cable as well and made one with a larger hole in the plate with a piece of 1/8" hardboard. you can use plastic too, but i had the hardboard.
philip Posted July 8, 2007 Report Posted July 8, 2007 phillip- you can make a new base plate for you router really easy. i have a porter cable as well and made one with a larger hole in the plate with a piece of 1/8" hardboard. you can use plastic too, but i had the hardboard. thanks man i'll do that i just thought everyone was using something i didn't know about. thanks mojo i'll do exactly that with hardboard.
