i need help finding 4 good 18 inch subs.
im stuck between
audioque
digital design
cactus sounds
fi audio's btl
atomic
can somebody help me find a good brand to use. thanks
What car? Where will the subs be located? Wall or no? What kind of power you thinking of runnin? Have you decided on an amp? If so, what kind? What's your electrical like? Do you want loud daily or high numbers?
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
ok tahoe.. zero gauge wire.. six kinetic batterys.. stetsom 14k2d does 16800 at one ohm so ill have it down to 4 subs so around 4200 a sub.. and it will be in a wall.
im stuck between
audioque
digital design
cactus sounds
fi audio's btl
atomic
I don't know if the audioque will take 4200 a piece. The BTL should as long as you don't clip it. IDK about the others. Maybe someone will chime in and help you out some more.
15.4" widescreen
What it does:
you forgot budget
R.I.P!
(Nov-29-2009)
92 explorer
current build
If you're going to push 4,200 to the each sub, i'd go with the BTLs, and just be a little conservative with the gains
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
look into some other companys
T3 Audio
Rd audio
Ground Zero
crossfire
R.I.P!
(Nov-29-2009)
92 explorer
current build
regardless of what you decide that is a shitload of power I am running 3500 watts to each of my btl 18s and they pound super loud but 4000+ you really gotta have a very very good enclosure just keep that in mind... hope this helps
  • Who's Online   0 Members, 0 Anonymous, 2422 Guests (See full list)
