I have an 04 coupe stang. Running two RF T2 15's in a 10.5 cu box. I'm hitting 149.2 decibels with a 39hz port. I was thinking of getting two Incriminator audio Warden 18's. Anyway I can squeeze as many db's out of my current setup. And any recomendations on squeezing even higher db's out of my future setup.
Thanks guys and gals
2004 Mustang
3 18s
6 crossfire bmf 1700s strapped @ .5
161.2 db Daily driver
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
http://www.youtube.com/Drek75633
Is it fully walled off or a half wall type setup?? Also how much power are u running??
Pioneer AVIC-N2
Do u have any pictures of the wall?? By adding power you should see a gain, additional bracing(idk how much u have now), resin inside the whole wall, etc. There are many small changes that can be done to pick up gains(this is without knowing the specs or anything bout the wall). Alot of tweaking walls is changing small things often and testing a ton, so owning a TL or similar meter just to see if you are gaining with box mods with help out a ton.
Easy way out would just be to get a ton of power, sum new woofers and build a new wall around them. I'm guessing that you want a big time daily setup, rather than just a wall that will do sum high numbers and sound like garbage daily.
Pioneer AVIC-N2
Yessir. My mustang is my daily driver and I want great SQ and SPL. I already have ppl around my town sayin oh shit. But I want more. Message me your email and I will PM you pics of the box and tell you more about the design right now.
2004 Mustang
3 18s
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
Also forgot to say. I can't drive my piece of shit truck all the time. That sucker has left me stranded on the side of the road plenty of times because an airline will blow or a bag will blow. Majority of the time. The battery is dead.
2004 Mustang
3 18s
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
