2/0 gauge?????
so im running 2 amps right now..(1)T20001bd and my 4channel but my 4channel amp power wire is kinda short so i was thinking if i could wire it from the fuse block(2/0) to the amp?..is it bad?..or should i just buy more wire?..
like power wire 2/0 from batt to amp ==================== T20001bd
4channel
each of the wire is fused so i dont think that would be an issue or would it?..
thanks!..
DUBIE
Dude, ya gotta give people more then 2 hours to reply to your post... It's a Saturday afternoon for christ's sake... People are probably working on their rides...
And I'd help, but I don't understand what you are trying to do... Your explanation is hard to understand...
2011 Dodge Durango Citadel AWD HEMI - LOADED
Stereo:  STOCK
Emergency Equipment:  Morotola - Federal Signal - Feniex - Gamber Johnson
Performance:  MOPAR Performance - Diablo
911 Calltaker / Diaptcher, Volunteer Ambulance Driver, Rescue Tech, Fire Fighter, Fire Policeman, Emergency Equipment Installer / Repairman
so youre saying you want to have one run 2/0awg to the fuse block, then 2 runs of wire from that, one to the RF and one to the 4 chan?
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
correct...
If you run a fused 2/0 to your distro, then 2 separate runs from the distro to your amps, that would be all good... that's the reason they made distro blocks in the first place...
I say fuse your 2/0 at the batt, and your distro should be fused and your golden...
Stereo:  STOCK
  • Who's Online   0 Members, 0 Anonymous, 745 Guests (See full list)
