does he know what he is doing? if not you can end up very easily with a shitty box that matches the performance of one that you buy in a store.
Yes he knows what he is doing
How much power are u running??
Pioneer AVIC-N2
Ok I have the box in my possession. To direct connect my subs to the amp I plan drilling a tiny hole so the wire can come threw. What should i use to fill in the hole so no air leaks. Would caulk work?
