ok so ive had my amp under my bed for about a 2months now,and today i got bored and decided to hook it up and wen i did i put the volume at 5 0f 35 , and added a lil bass then i made a "click" sound and the bass cut out so i took off the bass a the bass came in, ok i have stock 150 amp alt, 1 duracell 1000 amp battery, and one HC2400 in the back , one 250 amp fuse 0 gauge power and ground !
why is this happening?
Edited by 03navi
Vehicle: 2003 Lincoln Navigator
Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust
Amplifiers:Kicker Kx2500.1, MA Audio M700XE
Batteries: 1 Kinetic Hc2400 Battery
Electrical: STOCK Charging System! Tsunami 40farad Capacitor,
Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz)
Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter
Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter
Subwoofers: 2) 15 Power Acoustik Mofo
Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable
Video: http://www.youtube.com/2treo15
How did you set the gains? They may just be too high and sending it into protect.
Don't some amps have built in clipping protection circuit's?
Edited by 1992Chevy K1500
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
man the gain was 1/4
the bass was at 1/4 as well !
also whats clipping protection circuit's ?
Honestly, I just heard that some do. But (if I heard right and they exist), the theory would be to shut the amp down if it detects a clipped signal.
Try some other songs. Get a vid if you can.
15.4" widescreen
What it does:
ohh ok man!
i would x2 on that vid. what are your settings on your headunit?
most importantly, did you change ANYTHING on your system at all.
man my settings are treble is all the way up!
bass i always all the way down! i havnt changed anything!
i will do that vid ASAP!
what are the woofers wired to?
2.1 ohms!
i had this happen wiht my HK802sx, Take off the front cover and dust off your fets. and if you can, carefully dust off the board. i did this and worked just fine after that. also, i had mine with 2 hc2400s and a 200 a alt at 2 ohms bridged(its a 2ch amp) and i needed more battery power. so i would add another battery
Bills
KwB
Team DC Audio Midwest captain
  • Who's Online   0 Members, 0 Anonymous, 1880 Guests (See full list)
