03navi Posted November 4, 2009 Report Posted November 4, 2009 (edited) ok so ive had my amp under my bed for about a 2months now,and today i got bored and decided to hook it up and wen i did i put the volume at 5 0f 35 , and added a lil bass then i made a "click" sound and the bass cut out so i took off the bass a the bass came in, ok i have stock 150 amp alt, 1 duracell 1000 amp battery, and one HC2400 in the back , one 250 amp fuse 0 gauge power and ground ! why is this happening? Edited November 4, 2009 by 03navi Quote Vehicle: 2003 Lincoln Navigator Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust Amplifiers:Kicker Kx2500.1, MA Audio M700XE Batteries: 1 Kinetic Hc2400 Battery Electrical: STOCK Charging System! Tsunami 40farad Capacitor, Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz) Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter Subwoofers: 2) 15 Power Acoustik Mofo Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable Video: http://www.youtube.com/2treo15
1992Chevy K1500 Posted November 4, 2009 Report Posted November 4, 2009 (edited) How did you set the gains? They may just be too high and sending it into protect. Don't some amps have built in clipping protection circuit's? Edited November 4, 2009 by 1992Chevy K1500 Quote My comp setup (Not bad for what it is): HP Compaq Presario V6120US laptop with: 15.4" widescreen AMD Turion 64 X2 1.6GHz processor 2x1GB stick DDR2 SDRAM (667 Mhz) Seagate Momentus 500GB SATA HDD 128MB shared video memory Windows 7 Home Premium 64 bit 12 cell Lithium Ion battery (actual battery usage time: 6 hours) What it does: On a USB 2.0 Wireless card
03navi Posted November 4, 2009 Author Report Posted November 4, 2009 How did you set the gains? They may just be too high and sending it into protect.Don't some amps have built in clipping protection circuit's? man the gain was 1/4 the bass was at 1/4 as well ! also whats clipping protection circuit's ? Quote Vehicle: 2003 Lincoln Navigator Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust Amplifiers:Kicker Kx2500.1, MA Audio M700XE Batteries: 1 Kinetic Hc2400 Battery Electrical: STOCK Charging System! Tsunami 40farad Capacitor, Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz) Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter Subwoofers: 2) 15 Power Acoustik Mofo Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable Video: http://www.youtube.com/2treo15
1992Chevy K1500 Posted November 4, 2009 Report Posted November 4, 2009 man the gain was 1/4 the bass was at 1/4 as well ! also whats clipping protection circuit's ? Honestly, I just heard that some do. But (if I heard right and they exist), the theory would be to shut the amp down if it detects a clipped signal. Try some other songs. Get a vid if you can. Quote My comp setup (Not bad for what it is): HP Compaq Presario V6120US laptop with: 15.4" widescreen AMD Turion 64 X2 1.6GHz processor 2x1GB stick DDR2 SDRAM (667 Mhz) Seagate Momentus 500GB SATA HDD 128MB shared video memory Windows 7 Home Premium 64 bit 12 cell Lithium Ion battery (actual battery usage time: 6 hours) What it does: On a USB 2.0 Wireless card
03navi Posted November 4, 2009 Author Report Posted November 4, 2009 Honestly, I just heard that some do. But (if I heard right and they exist), the theory would be to shut the amp down if it detects a clipped signal.Try some other songs. Get a vid if you can. ohh ok man! Quote Vehicle: 2003 Lincoln Navigator Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust Amplifiers:Kicker Kx2500.1, MA Audio M700XE Batteries: 1 Kinetic Hc2400 Battery Electrical: STOCK Charging System! Tsunami 40farad Capacitor, Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz) Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter Subwoofers: 2) 15 Power Acoustik Mofo Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable Video: http://www.youtube.com/2treo15
Guest Posted November 4, 2009 Report Posted November 4, 2009 i would x2 on that vid. what are your settings on your headunit? most importantly, did you change ANYTHING on your system at all. Quote
Sampsonite Posted November 4, 2009 Report Posted November 4, 2009 what are the woofers wired to? Quote --Sampson 816-591-6592 www.kcrimshop.com
03navi Posted November 4, 2009 Author Report Posted November 4, 2009 i would x2 on that vid. what are your settings on your headunit?most importantly, did you change ANYTHING on your system at all. man my settings are treble is all the way up! bass i always all the way down! i havnt changed anything! i will do that vid ASAP! Quote Vehicle: 2003 Lincoln Navigator Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust Amplifiers:Kicker Kx2500.1, MA Audio M700XE Batteries: 1 Kinetic Hc2400 Battery Electrical: STOCK Charging System! Tsunami 40farad Capacitor, Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz) Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter Subwoofers: 2) 15 Power Acoustik Mofo Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable Video: http://www.youtube.com/2treo15
03navi Posted November 4, 2009 Author Report Posted November 4, 2009 what are the woofers wired to? 2.1 ohms! Quote Vehicle: 2003 Lincoln Navigator Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust Amplifiers:Kicker Kx2500.1, MA Audio M700XE Batteries: 1 Kinetic Hc2400 Battery Electrical: STOCK Charging System! Tsunami 40farad Capacitor, Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz) Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter Subwoofers: 2) 15 Power Acoustik Mofo Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable Video: http://www.youtube.com/2treo15
Bills Posted November 4, 2009 Report Posted November 4, 2009 i had this happen wiht my HK802sx, Take off the front cover and dust off your fets. and if you can, carefully dust off the board. i did this and worked just fine after that. also, i had mine with 2 hc2400s and a 200 a alt at 2 ohms bridged(its a 2ch amp) and i needed more battery power. so i would add another battery Bills Quote KwB Team DC Audio Midwest captain
