im gonna need 4 so they will need to be affordable. I need something that will produce a good clean rated power. Sundown, AQ, Crunch, Memphis etc. Im open to options and need some good solid input. Im gonna be clamshelling 20-24 woofers in the blazer with an RMS of 500w (Memphis PR 10s).
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
just so you know the pr10's rms is actually 250 tho it may take 500
Are you going with the D4's or the S4's?
Edited by kanarrjl
97 Honda Civic Sedan
Rear disc brake conversion
2" drop
17's
lots of exterior mods
SYSTEM
SoundStream VIR-5850 Dvd player
RE 6x9's and 6.5's
Soundstream DTR4.500
Soundstream DTR1.2200
8" RE-x in a t-line
Kinetik 1800
Plans
4-SA-8's
Another Kinetik
High output alt
My Cardomain
i know they are 250rms...i was just saying that cuz thats max so i figure if i can evenly distribute power between them they should be alright. lol there is logic behind my madness.
havent really given that any thought...more then likely the d4
Edited by jagblazer01
www.4xspower.com
do you know what surround those have?
the reason i ask is because i have a last years mojo 10 (right after the new style came out)
the rms is 500 the rep told me i should push it with a minimum 1000rms ive been pushing it with a rockford 500-2 and the surround has torn twice on me. this year the mojo or CM as they call it now has a rubber surround so id be carefull on what you push it with
Edited by kanarrjl
2" drop
17's
SYSTEM
RE 6x9's and 6.5's
8" RE-x in a t-line
Kinetik 1800
Plans
4-SA-8's
Another Kinetik
High output alt
My Cardomain
been a while since ive looked at them that closely. why? ill have to go up to the shop im buying them from and check them out a bit closer. Im getting an awsome deal on the subs thats why im going this route. crazy daily ground pounder
i owned a pair of 15" mojos last year and they were tanks...took power great. They didnt do a redesign on the PR's for this year. they are the same as last year so ill check em out
www.4xspower.com
did you have any problems with the surround? Besides that i love that sub it sounds amasing for 1 10 ive had kids come up to me and think i was running 2 15s lol, maybe ive just been unlucky twice, did you build the box to memphis specs?
2" drop
17's
SYSTEM
RE 6x9's and 6.5's
8" RE-x in a t-line
Kinetik 1800
Plans
4-SA-8's
Another Kinetik
High output alt
My Cardomain
i had 2 15s in a box that was 8cu ft. so it was a little larger then memphis spec i believe. pushed them with the memphis 4kw amp and they took it like a champ. no problems at all
www.4xspower.com
you still have that 4kw? if so why not get another?
Edited by kanarrjl
2" drop
17's
SYSTEM
RE 6x9's and 6.5's
8" RE-x in a t-line
Kinetik 1800
Plans
4-SA-8's
Another Kinetik
High output alt
My Cardomain
Im very happy with my sundown 2000d stays cool, i kinda want to get another soon!! Out of what you listed i would probably only go with either sundown, rockford, stetsom, dc, aq.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
