SOLD
ORION HCCA sub dual 2 ohm - $300 + shipping
I have an orion hcca dual 2 ohm subwoofer. It has less that 30 min of play time on a Kole KX1-5500D amp. It still needs to be broken in. My plans have changed, so this thing needs to go. This Orion is LOUD! I also have a 1" mdf box built to orion's specs.
The new Orion HCCA subwoofers are the baddest subs on the planet. Hands down. You could call our HCCA sub a “super woofer”, but really it's the superior woofer! With its massive 3" high temp voice coil and immense motor, this subwoofer can reach as much as 4" of travel. And everyone knows that more travel equals more BASS!
10" HCCA Series Dual 2 ohms Subwoofer
Power Handling:
Peak: 3000 watts
RMS: 1500 watts
Polypropylene cone woofer
Rubber tri-radius symmetrical surround
Dual flat conex spiders with loop stitched tinsel leads
Enhanced voice coil cooling systems
High-temperature PAARC (Polyester Amide, Amide Resin Coated) voice coil
Copper wound voice coil on an aluminum former
Sensitivity: 84 dB
If you blow the subwoofer, there is a replacement cone kit that allows you to easily swap out the blown/burned voice coil and surround with a new one. The replacement kit allows you to keep the magnet and basket, therefore saving money as you do not need to buy a new sub.
Edited by barros57
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
This topic is now closed to further replies.
