21 members have voted
  1. 1. What enclosure do you think I should build?
    • 4 cubes to 33-35Hz
      8
    • 5 cubes to 33-35Hz
      1
    • other (explain below)
      1
    • 4 cubes sealed
      1
    • 3.6 cubes to 33-35Hz
      1
Posted (edited)
I am debating on a box to build for my two Alpine Type R 12's for a daily setup. I want clean, accurate bass down low. The three boxes I am looking at are posted above.
I listen to almost anything with beat in it, lot of rap, techno, C&S, rock, just want it to be accurate with everything.
I have 36x16x35 inches at my disposal if I build inside the trunk of my 1996 Pontiac Grand Prix.
the 4th order would be ported through the rear deck most likely.
Let me know whatcha think!
Edited by ktownsdriftking
Too many projects, too little time...
How much power?? I have a ton of experience with Rs, mostly 12s + 15s.
The 12s off around 1500w to each pair was the loudest(daily tuning) in 2.3ft3 per woofer @ 35hz w/ 30in^2 of port per sub. We tested it in a bunch of box setups from anywhere from 1.5ft3-2.5ft3 and this was the best we found.
1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN.
Pioneer AVIC-N2
(12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each
Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s
26ft3 @ 33hz w/ a ton of port area
156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
I will be using an MTX 81000d which is rated 1000w at 2ohm but I've heard claims it does up to 1500. But its only fused to do 864 watts...(150Ax14.4V/2x.8?) So IDK what power I'm going to see.
Was that a common chamber or split chamber enclosure?
ive ran many type rs in my grand prix in quite a few boxes the lowest ive had it tuned to was 35 which is where im at right now it sounds nice and clean it could be cleaner if i had a better amp but its at 2 cubes per sub after displacement ive had them up to 2.5 per sub and its nice sound but the 2.5 was at 40 hertz whats the most power u have put on them? mine were getting kinda warm at about 1400 but its pry cuz of the cheap amp
RIP The 03 prix!
New Ride
2003 Chevy Tahoe Z71
4 DC LVL 4 18s (2 currently installed)
2 DC PAI.2000 (1 currently installed)
1 DC PAI-120.4
btw i had them sealed and it was only about 1.3 cubes per sub but they slammed so the 4 cubes sealed mite work
RIP The 03 prix!
New Ride
1 DC PAI-120.4
Common chamber and for 2 $100 subs it was pretty nasty off only around 1500w.
Pioneer AVIC-N2
I have been told my amp can do 1500 at 2 ohms at 14 volts but I do not have the best voltage. I know my lights dim a bit but don't know what my voltage is dropping to ATM.
Idk, I may just build a few boxes and see what happens.
if you have room id see about the 4th order they sound great on music and get great lows to along
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
  • Who's Online   0 Members, 0 Anonymous, 599 Guests (See full list)
