Couple Quick Q's(With Diagram)
OK I have a few quick questions so I figured I would post up a diagram to make things easier to explain.
Ok now for the questions.
1. Is that the correct amount of fusing in the Diagram?
2. What size fuses would I need using that amount of power. Alt is factory, 136A or so. I assume this also depends on the batteries in which I am using. If so, what batteries should I use to power this using the factory alternator?(Yes I will upgrade the alt if needed later on) Kinetik website suggests 2xKinetik HC1400 along with the battery under the hood.
Thanks for any help fellas.
aggballeralex
The Build
what gauge wire are you using? the fuse in your diagram is dependent on the wire size since the fuse protects the wire from melting. And to answer your question you have a good fuse setup, atleast in my opinion
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
  • Who's Online   0 Members, 0 Anonymous, 952 Guests (See full list)
