I've been running my setup for about a month with no problems till yesterday when the amp turned off during play.
I felt the heatsink and it felt pretty warm. Im worried that it overheated, but in that case shouldnt a thermal light or protection light kick on to save the amp?
I checked all the fuses and no problem there. Got out the DMM and check the power supply at the fuse and its getting proper voltage. Checked the remote wire and it reads .06 (seems very low, but not sure what its supposed to be). After a few hours I removed the power wire to the amp and re-connected it and then the amp worked again. Later that day on the way home, it went out again, and it won't turn on. Is the amp done for good, after 3 weeks of normal use?
I have the gain set at 3/4 and am running all 1/0 gauge, a powermaster D5100R as a secondary battery in the trunk, big 3, and stock alt.
I never turn the HU up more than 3/4 volume either.
Any help on this would be appreciated.
2000 Blazer 4dr
-24" Boss 330s
-Lowered 2/3
-5000k Hids w Projector Retro
-Candy tails
-LED interior lighting
-20% tint 35% windshield
-Alpine 9886 HU
-RF P1462 Dash
-RF P1652 Front
-RF P1652 Rear
-Two 18" Fi BTLs
-MB Quart Onyx 4.80
-Two Audioque AQ2200Ds
-Xs Powerr D5100, 2 Powersafe G31s
-Knukoncepts 1/0 wire
-Mechman 270 Alt w Boost Module
-10.4 Net @ 28hz 140sq.inch of port
My Youtube Channel!!
Check Your Inline Fuse, Or etc., Make Sure That The Fuse Is Not Damaged If Its Under The Hood, I Had A Friend Thats Amp Did The Same Thing It Was His Fuse, It Was Black And Pretty Messed Up, Also Check Amp Fuses
Hope This Helps
--Toady
Sorry Didnt Read Your Message Right, Umm If You've Already Checked The Fuses Make Sure The RCA'S Are Not Pinched, Some Times when the rcas get pinched it does this
How'd you set the gains? You could be clipping it. Which is very bad.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
Ive got a feeling its toasted...by looking at your electrical setup...i ran one for a very long time and it was a current hog.
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
remote wire voltage is supposed to be around 12-15v. check the connection on the back of your headunit if you have it wired to there. check for ANY pinched wires. check your ground that its tight and on bare metal. and your gain looks like its wayyy too high. did you set your gain with a multimeter, o-scope, or by ear?
Edited by Kranny
I set the gain by ear, just under 3/4. I doubt its an RCA problem, it would still power up.
Its very odd that it all the sudden took a shit, I've heard that this amp is a reliable beast, but maybe its a sign that my alt is getting weak or I just need to upgrade to a H/O.
Has anyone had any luck with returns to sonicelectonix as far as amps go? I bought this amp new less than a month ago and would hate to have just thrown away 600$ :( Also, does rockford repair amps for a reasonable price if not free under warranty?
2000 Blazer 4dr
-24" Boss 330s
-Lowered 2/3
-Candy tails
-Alpine 9886 HU
-RF P1462 Dash
-RF P1652 Front
-RF P1652 Rear
-Two 18" Fi BTLs
-MB Quart Onyx 4.80
If for some reason my remote wire coming from the HU is not giving enough voltage, could I use a acc switched 12v source?
I would love to set my gain with an o-scope, but I don't have access to one. What would be a suggested level to set it at safely until I can properly set it.
2000 Blazer 4dr
-24" Boss 330s
-Lowered 2/3
-Candy tails
-Alpine 9886 HU
-RF P1462 Dash
-RF P1652 Front
-RF P1652 Rear
-Two 18" Fi BTLs
-MB Quart Onyx 4.80
yes you can, you can also use either a relay or a physical switch.
i cant tell you that. every piece of audio equipment is different. pick up a digital multimeter from a local store (Fluke is highly recommended) and tune gains via this chart.
^ Thanks alot!
I jumped the remote wire with a acc/switched 12v source and the amp turned right on! Now it sounds like the problem is with my cheap kenwood cd player no supplying the 12v remote source. I plan on upgrading to a indash tv soon anyway.
I'll run a new wire to the amp from a switched source to the amp and then use that chart. Only thing im not sure of is what setting on the voltmeter do I turn it to?
I have this voltmeter
2000 Blazer 4dr
-24" Boss 330s
-Lowered 2/3
-Candy tails
-Alpine 9886 HU
-RF P1462 Dash
-RF P1652 Front
-RF P1652 Rear
-Two 18" Fi BTLs
-MB Quart Onyx 4.80
  • Who's Online   0 Members, 0 Anonymous, 651 Guests (See full list)
