Can you give us the formula? I'd like to try it myself.
Heres the formula I use ethat I got from him. You can also use duraglass. Much stronger.
"I put in 16oz of body filler + 7oz of resin...... mix well. I use a mixer and a drill. Then add 5cc of MEKP hardener and mix again.
If it is over 90 degrees out, less MEKP.
This mixture is just a little less liquid than latex paint."
Awesome. Thanks.
BTW, I have evercoat "lite weight" body filller and some off-brand fiberglass (not bondo) that works quite well. Will that work?
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
Awesome. Thanks.
evercoat's good stuff. It will for sure work. Cheap resin is usually just thicker and harder to work with. But just practice on something first.
It's off-brand, but not cheap (60-something a gallon) and works well. I don't have anything to compare it too, so I can't say for the thickness. I've got a good practice piece, though.
Thanks for the advice.
15.4" widescreen
What it does:
np, good luck.
Nice doors.
I know I said it before on that other forum, but they are good enough to say it again.
Now get back to work.
Building The Best.....Repairing The Rest
The bitter after-taste of a poor quality job will last far longer
than the sweetness of that cheap price!
Nice doors.
^^the man right there
Thanks man, I appreciate that, alot. Ive gotta do a box repair and then ill get back to work :sorry:
Your sig looks sick, thats the first time i've seen that FGF one.
  • Who's Online   1 Member, 0 Anonymous, 1618 Guests (See full list)
