You should take a look at the Chevy HHR if space, fuel efficiency, and price are your main considerations. The car has a funky shape for a reason you would understand by looking inside. It is extremely good on gas and can be found for cheap.
The Toyota Scion Xb is also a good choice for similar reasons, but is a little more expensive than the HHR.
Besides that, both little cars take bass like champs!! :hairtrick: vs. :hairtrick:
An early 2000's Ford Crown vic. With the right engine mods (new air intake, exhaust, aluminum drivershaft, and a good rear-end gear ratio) they will get above 20 MPG as long as you take it easy. My dad's 04 gets like 24 or so with those same mods. The aluminum driveshaft and intake (from a caddy with the same engine as his) cost him just over 100 and the exhaust was around 100 because we had a good friend do it for us.
The KBB value on an 02 Ford Crown vic is between 5,000 and 6,000. They're trunks could easily fit 4 12" as long as you know what you are doing. I believe there's something like 12 cubic feet available in the trunk without the spare tire.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
