83Maro Posted November 9, 2009 Report Posted November 9, 2009 ok so i going to end up getting a cavalier and putting in a 12 fi btl with a 2500 amp from rockford knowing i need to do another battery in the back for more power what else would i need to do? oh yea idk if the counts but i putting in my eclipse head unit from the maro into the cavalier to.. i can get a link of the head unit i have if it helps at all and the second one is i got a 83 camaro going to be building a 383 engine for it.. would having like two stock or 150 amp alternators work? for the same set up ( 12 fi btl 2500 watt amp and another batter) plus would you need capacitors to?
white4d96 Posted November 9, 2009 Report Posted November 9, 2009 No caps for sure. I would say it depends on the alts. For sure do the big 3 on both cars and one or two runs of 1/0 to the back. You may be able to get away with stock alt but I'm not 100%. You may want to do two or even three rear batts? Don't quote me. Too many projects, too little time...
83Maro Posted November 10, 2009 Author Report Posted November 10, 2009 wow that many batteries really? i figured just a bigger alternator another battery for the cav would do and maybe just a capacitor for the cav
white4d96 Posted November 10, 2009 Report Posted November 10, 2009 I'm not sure, depends on the size of the batt. I think I heard a rule of thumb was to look at the amp-hours of the batt (A/H) and get 100AH for every 1000 RMS watts. And caps really don't do anything for voltage drop, they can actually make it worse. Too many projects, too little time...
83Maro Posted November 17, 2009 Author Report Posted November 17, 2009 what if i go with a big 3 in the back?
Iraggi Alternator Posted November 17, 2009 Report Posted November 17, 2009 Doing dual 150's will work. Its a lot of work just for 300 amps tho. Let me know if you need the 150's Dom Iraggi
