FiQ150db Posted November 13, 2009 Report Posted November 13, 2009 Will be running two Atomic 5000.1's and 4 BTL 15's (10kwrms) Power supply will be : 250a alt and 5 C&D Dynasty ups Max rate 350's - 93ah each, 4200a short circuit current and 350w per cell. Space wise I am TOTALLY maxed out. Will this be adequate ?
Marlo Stanfield Posted November 13, 2009 Report Posted November 13, 2009 Yea you should be alrite with that setup... How many power/ground runs are u doing?? 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
FiQ150db Posted November 13, 2009 Author Report Posted November 13, 2009 Yea you should be alrite with that setup... How many power/ground runs are u doing?? around 2-3
Marlo Stanfield Posted November 13, 2009 Report Posted November 13, 2009 I'd suggest at least 2 runs per amp at the minimum 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
