Im currently working on a whole new installation. Going all out and doing everything the right way and leaving no stone unturned. Ill get pics up as I get them. I have my three amplifiers setting here and have a nice pioneer head unit that will do until I can get my double din. Doing a great build on a budget isnt easy but I am stretching every dollar and scratching up cash where I can with small jobs on the side. As of right now these are the only pics I have.
I'd suggest getting the tint and alarm done before anything else if you're planning on having any system in there. Also you're gonna have one hell of a time fitting 3 large amps, batts and a sub enclosure in a small extended cab area.
Pioneer AVIC-N2
Already got basic plans layed out and everything will fit. It will be one extra batt in the back. I will be putting in the alarm the tint before the system. I just want to get the rack and enclosure built so that when I get the rest done I can just drop everything in. Im multitasking on this project so that it will take less time to get done. So say im working on putting in the deadener I can also put some time in on the rack and enclosure too. Im going to have everything work into place like a puzzle to save time and it gives me more to do to occupy my time when im not working. I will be ordering an alarm wednesday after my check is in my checking account.
Can anyone help me with plans for an enclosure?
  • 1 month later...
  • 1 month later...
Will keep everyone updated. I will have to borrow a cam seeing as mine died. Ill upload pics of what Ive done on the inside as far as getting rid of that damn tar based factory deadener. I have a shop pack of damplifier pro on the way. Thanks Ant for that 10% off code. I have a 260 amp Iraggi alt on the way as well. Have some knukonceptz here I won in a raffle which I plan on using for my big 3.
Thanks to all of SMD for teaching me so much and for the great deals I have received here that has helped greatly with my build.
Out goes the factory deadener and soon to come is Damplifier Pro. Will be deadening before any wiring or alarm installation. This is so I dont have to fight the deadener under any extra wiring and in case of having to re wire anything.
