Mikes 93 chevy silverado HCCA build.
Houston, we have light. 4 hi mod done, and relays and switches reinstalled
EDIT:...ohh i forgot about the 2 lights on the hood :/
put the four on top down on a grill guard. A friend of mine knocked a couple off.
EDIT: had to hide my tags. =]
84 K5 Blazer
3" body, 2" Suspension
35" Maxxis Bighorn
100amp Alt
Marine deep cycle for the amps (freebie)
KnuKonceptz 1/0
8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz
Audiopipe AP-18001D
RF 5x8's in the kicks
Almani 5.25 comp. in back
Kenwood KAC-645
--IN THE FUTURE--
None.
<!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
kx519, I had a brushguard awhile ago with 2 KC daylighters. I sold the lights with the plow. I still have the brushguard and I might be buying 5 more KC's from a friend.
and i dont know how to set the gains with an o-scope. I can do it with a multimeter/dmm,
I will try to find that vid
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
I was figuring out how to use the o scope today. i just had it hooked up to the computer headphone jack from a external speaker to the computer. Would you call this clipping? near the end when i turned on the bass boost. It goes from a good sin wave to a pointy edge,.
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
Looks to me like you didn't calibrate the scope properly. Do you have a manual for it? I would suggest reading over it until you fully understand how to operate it.
With the o-scope i use,
i plug it into the wall and turn it on.
i connect the scope probe to the cal. hook
the line should be directly in the center, if its not adjust it with the position knobs
if the line is slanted you must adjust the trace level. usually you have to use a small phillips screw driver.
all of the calibration knobs should be turned all the way to the right( this is for the scope i use, may apply for you too)
i always start by setting all the knobs to the center and then working from there
once the scope is calibrated you can go on to checking your headunits max volume before clipping
followed by setting your gains
hope this helps you out a little
(Headunit) Pioneer DEH-P3100UB
(Speakers) Phoenix Gold RSd 65cs
(4 Channel) Alpine MRP-F300
(Subs) 2 15" Audioque SDC2.5
(Box) 7.27 cubic feet tuned to 31 Hz
(Mono Amplifier) Elemental Designs Nine.1
(Wiring) 1/0 Knukonceptz KLMX
(Batteries) 2 C&D Tech 75 a/h
Thanks! this helps alot.
But where should i connect the ground when i am calibrating it? And how do you know when it is calibrated? -just when you have a straight flat line on the X axis?
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
  • Who's Online   0 Members, 0 Anonymous, 1641 Guests (See full list)
