Mikes 93 chevy silverado HCCA build.
Thanks! this helps alot.
But where should i connect the ground when i am calibrating it? And how do you know when it is calibrated? -just when you have a straight flat line on the X axis?
the ground clip does not have to be connected when calibrating. Just the scope probe, mine has an attachment with a little hook on it. When you hook the scope probe to the calibration hook it should be a square wave form and read 2 volts peak to peak. here is a pic. it's crappy but you should get the idea
edit: can those red calibration knobs be pressed in? if so they should be.
a good rule of thumb set all knobs to 12 o'clock. all calibration knobs to the right. push all buttons in. keep x/y axis button out.
(Headunit) Pioneer DEH-P3100UB
(Speakers) Phoenix Gold RSd 65cs
(4 Channel) Alpine MRP-F300
(Subs) 2 15" Audioque SDC2.5
(Box) 7.27 cubic feet tuned to 31 Hz
(Mono Amplifier) Elemental Designs Nine.1
(Wiring) 1/0 Knukonceptz KLMX
(Batteries) 2 C&D Tech 75 a/h
is this right?
no the red calibration knobs cant be pushed in, but they are turned all the way to CAL'D. Volts/DIV is on .2 the time Time/DIV is at .5
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
it looks pretty good to me. the top line looks slightly high though. also adjust your trig level so the line lines up right at the edge of the grid.
edit: it can get extremely tricky when trying to tune your system with an o-scope. I thought it was as easy as it sounded until i posted a thread up on diyma.com. i'll link you to it. http://www.diymobileaudio.com/forum/diy-mo...ng-o-scope.html
to be honest after reading what some of these guys posted it scared me away from using the o-scope. i need to further my knowledge about it more. i know the basics and that's about it.
I just tried it with another one and they are the same, so i think its right. Thanks alan412
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
no problem. i noticed in the picture that you had the ground clip connected. that is not necessary, i'm not sure if it will effect it, but try to calibrate it without the ground clip connected.
oh... now im confused..
why are you confused? from the link to diyma.com or because of the ground clip???
ground clip doesnt make a difference, i tried it both ways
the link to diy. Loading the outputs? probe ground to a driven output?
haha I have a lot more reading to do...
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
Yeah dude it really discouraged me from using the o-scope. I need to further my knowledge about it. I've just been doing everything with my dmm lately. I don't want to take the risk and screw something up. I'm pretty sure thats probably how i just blew my sub lol.
I noticed you were 18, im 18 as well. what type of job do you have? Looks like you do pretty well with all that equipment you have. Nice build btw
I work @ gander mtn, Northern Tool and equipment, and for the city. Im thinking about going into electrical engineering at the U of MN next year. How about you?
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
  • Who's Online   0 Members, 0 Anonymous, 1641 Guests (See full list)
