How could I do a big 3 with this alternator
So how can I do a big 3 with this alt, im not sure what to do, unless i try and do a big 3 with a 4ga wire to the battery, and 0 on the other 2 grounds.....
any ideals? its just a small space and a small diameter bolt..
144+ DB'S OUT OF A CONVERTIBLE
12" Funky Pup Subwoofer (The worlds most powerful subwoofer)
6" Aero Ported Box
Hifonics - Bxi2010-D
Pioneer Deck
RD Audio - Front Speaker
Rockford Fosgate - Rear Speakers
KnuKonceptz - 0 Gauge Wire
KnuKonceptz SS Karma - 10 Gauge Sub Wire
KnuKonceptz - Krystal Kable Rca
Big 3 - Upgrade - 0 Gauge
Kinetik - Hc1800 Battery
Remove or cut the plastic off and run the 1/0 to it.
-Dan Kasun
05' Dodge Ram 1500 QCSB Hemi Blow-thru build in progress.
2 RD HW18's, RD D9, 5 Deka 9a31's, 6th order blow-thru box, Eclipse 7200mkii HU, 140' Knu Kollossus wire. DC Power 270xp Alt, Etc.
exactly!
does the plastic piece come off when you remove that nut on the +charging output?
Um Im not sure, It may, but if I remove it I will touch the rest of the alt with the power cable,..
Idk maybe I can grind the 0g's ring down enough to fit inside better..
6" Aero Ported Box
Pioneer Deck
Ok, just take off or cut the proper amount of the plastic off, and then leave that 1st nut on the stud, add a washer, then install the 1/0 terminal, and use another washer and nut. The 1st nut will act as a spacer to allow plenty of clearance for the wire and terminal.
-Dan Kasun
Awesome ima do it,
thanks everyone.
6" Aero Ported Box
Pioneer Deck
  • Who's Online   0 Members, 0 Anonymous, 420 Guests (See full list)
