Dee in Dallas tahoe build 2lvl4 xl 18's powerbass 5k
Looking good man, now just on to the daytime vids so we can actually see what's going down lol.
What are u hoping to see on the meter with it?? Dash, sealed up, TL
Pioneer AVIC-N2
Im looking and hoping for a 151 0r 152 they say i might get it after a breakin of subs and we go full tilt its wired @ 2 ohms now and i did a bass sweep 30 min after i drop them in the enclosure and did a 46.5 @ 44Hz sealed on TL so i think i can make it next month !!!!!
153.3 @ Turkey Drag 2009
Spl Modified 1001-2000 - Derrick Jones my alias... Wudn't accept DEEz NUTz !!!
That setup definitely has the potential to put up the numbers ur hoping for and I'd be dissapointed to see anything below a 150.5 @ the dash, all sealed up. What are your enclosure specs?? and what are u peaking at??
Pioneer AVIC-N2
9 cubes after,and tuned to 32 hz...
Is that Prometh & sprite..? Thats The SHIT!!
Mind need to send me a Couple bottles Of the Syrup!
Anyways Hows that PB amp doing..? You guys should clamp it to see what kinda power it Actually Doing!
And Sounds like its Bumpin! Looks good guys!!
theamp is badazz bro. tha guy that built my box clamped them already and did a 156.5 with a Lvl 5.....OUT OF HIS TRUNK !!!!
i doubt you will see a 152. no offense.
but going from a 46.5 to a 52 is no joke.
I was thinking the same thing but I just can't see how this won't do at least a 150+ @ the dash... Gotta remember though that the amp is only @ 2ohms right now and will eventually be running @ .5ohm where these amps turn into sum absolute beasts. Currently @ 2ohms he's prolli seeing around 3000w and @ .5ohm I've heard that these will do around 6k, so that's doubling the power alone right there.
Seems like that enclosure is a bit small for those subs, but I guess only time will tell how it does after wiring down to .5ohm, breaking in the subs, and dialing everything in fully.
To the OP - What hz are you peaking at??
Pioneer AVIC-N2
didn't see the part about being at 2 ohms
it might be possible at .5 ohms then
