Ok, income tax is just around the corner and new money will be coming in!! After alot of research and blowing up a pair of RE subs im turning to FI!! I am very interested in two of the FI Q12 D1 subs. Cant afford the BTL's!! Anyway, the site suggests a ported box tuned to 32 hz and 2.5 cubes per sub. I am trying to use the RE calculator for 2 subs so i can get the cut sheet and build the box. How do i calculate? I also dont understand the square port part. IThe box is going in an 86 Monte Carlo SS and i have about 40"Wx19"DX17"H to work with. Oh, the amp will be an AQ2200D
Edited by davewms9605
Current Setup:
Sony CDX-7401UI
2- 12" Alpine TypeR DVC2ohm Subs
Custom ported box
4-American Bass 6.5in SQ-6B Mids
4-Pioneer TS-T15 Tweeters
2-Crunch P1500.1 Mono Amps
2-runs 1/0 GA KnuKonceptz
KnuKonceptz RCA's
1-Stinger SPV44 Battery
Coming soon:
250 Amp Alt
Custom Door Panels
Second Skin Sound Deadner
All in my 1986 Monte Carlo SS!!!
So, of ALL the members here, cant noone help? Daily bump for a guy in need!!
Current Setup:
Sony CDX-7401UI
Custom ported box
KnuKonceptz RCA's
Coming soon:
250 Amp Alt
Custom Door Panels
Im trying to figure out how to get the best box i need to match the recommended tuning for the Fi Q 12,s and im stuck on the part that says "12-16 inches of port per cubic feet of volume" How do i calculate all that to get the right measurements of the box.
Current Setup:
Sony CDX-7401UI
Custom ported box
KnuKonceptz RCA's
Coming soon:
250 Amp Alt
Custom Door Panels
Ok, look guys, all im trying to do is find out the correct way to get the right box dimensions. If someone can show me how to do it, great. If someone can design a box for me, even better! Again, im just trying to have a foundation to get started on something new! I want alot of bass but all i can afford is 2- Fi Q12's. I looked at the AQ's but figured the Fi's would be better. Also, the amp i want to push them with is a AQ2200
Current Setup:
Sony CDX-7401UI
Custom ported box
KnuKonceptz RCA's
Coming soon:
250 Amp Alt
Custom Door Panels
take the square port area and divide it by the cubic feet of the box (ft3). and it should be between 12 and 16. if its under 12, make the width of the port bigger, if over 16, do the opposite
put this in the re calculator
W 40''
D 19''
H 17''
Port width 4''
port piece 2 length 4''
came to 32hz at 5.1 cubes before displacement and bracing
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
Thanks alot!!!
Current Setup:
Sony CDX-7401UI
Custom ported box
KnuKonceptz RCA's
Coming soon:
250 Amp Alt
Custom Door Panels
W 40''
D 19''
H 17''
Port width 4''
Thanks for the input, u say BEFORE displacement, since im new at the box building thing please bear with me, once i put it together and have bracing, wouldnt that bring the cubes down? is that ok? do i need to make the box bigger? im still a noob on some things!!
Current Setup:
Sony CDX-7401UI
Custom ported box
KnuKonceptz RCA's
Coming soon:
250 Amp Alt
Custom Door Panels
after bracing and the space the sub take up, you are looking from 4.5-5.0 cubes. depends what kind of bracing you use, i personally like wooden dowel rods.
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
