davewms9605 Posted November 21, 2009 Report Share Posted November 21, 2009 (edited) Ok, income tax is just around the corner and new money will be coming in!! After alot of research and blowing up a pair of RE subs im turning to FI!! I am very interested in two of the FI Q12 D1 subs. Cant afford the BTL's!! Anyway, the site suggests a ported box tuned to 32 hz and 2.5 cubes per sub. I am trying to use the RE calculator for 2 subs so i can get the cut sheet and build the box. How do i calculate? I also dont understand the square port part. IThe box is going in an 86 Monte Carlo SS and i have about 40"Wx19"DX17"H to work with. Oh, the amp will be an AQ2200D Edited November 21, 2009 by davewms9605 Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!! Link to comment Share on other sites More sharing options...
davewms9605 Posted November 22, 2009 Author Report Share Posted November 22, 2009 So, of ALL the members here, cant noone help? Daily bump for a guy in need!! Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!! Link to comment Share on other sites More sharing options...
Guest Posted November 22, 2009 Report Share Posted November 22, 2009 how do you calculate what?...and what part of the port. its so vague Quote Link to comment Share on other sites More sharing options...
davewms9605 Posted November 22, 2009 Author Report Share Posted November 22, 2009 Im trying to figure out how to get the best box i need to match the recommended tuning for the Fi Q 12,s and im stuck on the part that says "12-16 inches of port per cubic feet of volume" How do i calculate all that to get the right measurements of the box. Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!! Link to comment Share on other sites More sharing options...
davewms9605 Posted November 22, 2009 Author Report Share Posted November 22, 2009 Ok, look guys, all im trying to do is find out the correct way to get the right box dimensions. If someone can show me how to do it, great. If someone can design a box for me, even better! Again, im just trying to have a foundation to get started on something new! I want alot of bass but all i can afford is 2- Fi Q12's. I looked at the AQ's but figured the Fi's would be better. Also, the amp i want to push them with is a AQ2200 Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!! Link to comment Share on other sites More sharing options...
Guest Posted November 22, 2009 Report Share Posted November 22, 2009 take the square port area and divide it by the cubic feet of the box (ft3). and it should be between 12 and 16. if its under 12, make the width of the port bigger, if over 16, do the opposite Quote Link to comment Share on other sites More sharing options...
hotshot27 Posted November 22, 2009 Report Share Posted November 22, 2009 put this in the re calculator W 40'' D 19'' H 17'' Port width 4'' port piece 2 length 4'' came to 32hz at 5.1 cubes before displacement and bracing Quote Current Setup: Factory HU with LOC mids/highs-Insignia components Sub- E8 in bass tube Amp- sae-1200d Show Setup: HU-Sony MEX-1HD (brings massive respect for sony) fronts - Infinity Kappa perfect comps rears- Infinity Kappa coax mid/high amp - Autotek 5600 Subs - 2 RE SE 15's Sub Amps - 2xSAE-1200D Box - 5cubes sealed Wire- Lots of Knu 1/0 SECOND SKIN Link to comment Share on other sites More sharing options...
davewms9605 Posted November 22, 2009 Author Report Share Posted November 22, 2009 take the square port area and divide it by the cubic feet of the box (ft3). and it should be between 12 and 16. if its under 12, make the width of the port bigger, if over 16, do the opposite Thanks alot!!! Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!! Link to comment Share on other sites More sharing options...
davewms9605 Posted November 22, 2009 Author Report Share Posted November 22, 2009 put this in the re calculatorW 40'' D 19'' H 17'' Port width 4'' port piece 2 length 4'' came to 32hz at 5.1 cubes before displacement and bracing Thanks for the input, u say BEFORE displacement, since im new at the box building thing please bear with me, once i put it together and have bracing, wouldnt that bring the cubes down? is that ok? do i need to make the box bigger? im still a noob on some things!! Quote Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!! Link to comment Share on other sites More sharing options...
hotshot27 Posted November 23, 2009 Report Share Posted November 23, 2009 after bracing and the space the sub take up, you are looking from 4.5-5.0 cubes. depends what kind of bracing you use, i personally like wooden dowel rods. Quote Current Setup: Factory HU with LOC mids/highs-Insignia components Sub- E8 in bass tube Amp- sae-1200d Show Setup: HU-Sony MEX-1HD (brings massive respect for sony) fronts - Infinity Kappa perfect comps rears- Infinity Kappa coax mid/high amp - Autotek 5600 Subs - 2 RE SE 15's Sub Amps - 2xSAE-1200D Box - 5cubes sealed Wire- Lots of Knu 1/0 SECOND SKIN Link to comment Share on other sites More sharing options...
