MTX 9500 box help
I have a set of T 9512-44 dual 4 ohm 12's in a 1.5ft3 (each, seperate enclosures) and it sounds like crap. I need to design a new box but the specifications rec. a box between 1/1.75ft3. How does everyone figure out how large a box to build? I want to be tuned around 34hz and I can go big if I need to.
MTX 9512-44
Starting From Scratch!!
i would try the one mtx recomends like the one at the bottom of the spec sheet
That is basically what it is in right now and it maxes out in the low 130's. Rec. box size sucks ass!
I just plugged the numbers into the RE box calculator and it says I'm tuned to 49hz in the currernt box, no wonder is sounds like crap! So anyone else have any help other than try and try again? I'll try the 5 cu ft enclosure unless someone else has a better idea.
Edited by mhuck123
Yeah recommended box size is often made of suck and fail.
5 cubes total, common chamber assuming they're running off the same amp.
Yup, It's a Zapco 9.0. Any ideas on port size? The box will be facing up through the rear deck. The whole thing is cut open and will be woofer port woofer.
id do to woofers with one port for both and tuned around 32-35hz
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
  • Who's Online   0 Members, 0 Anonymous, 676 Guests (See full list)
