Hey,
Just bought a new(er) car.. its a 95 caprice with the 4.3L v8 L99 engine...
drives just fine, low miles "around 80k", and trans seems okay "not the best, but good"
anyhow...
When i test drove it for 30 min. or so.. no CEL "check engine light" appeared..
drove it off the lot and not even 5 min. a CEL light came on.. but nothing happened "didn't hesitate or make a weird noise, just appeared"
and it happens totally randomly.. will if i leave the car off for like 5 min. it'll disappear...
any idea what it could be ?? OH !!! and its ODB1 so i can't test it at the zone.. autozone
more than likelly just your oxygen sensor. if it's never been changed then it's pry bad with that many miles on it. yushould usually have your oxygen sensor changed every 75k miles i believe
"i'd rather die like a man than live like a coward" quoted from Tupac
yep, i had a same problem before.
with an OBD1 vehicle you should only have 1, maybe 2 sensors and they will pry run around $30 each. you pry want to check the headers, before the catylitic converter (cat) and after the cat just in case you do have more, but i'm certain you don't.
same thing happens to me...if I leave my bass on for a while in park just idling my CEL comes and I know its my O2 sensor cause ive checked the code multiple times...but it goes away every time until i do the same thing again lol
<div align='center'>03 RAV4
18" DC Level 4 XL
Knukonceptz 1/0 gauge
AudioQue 2200D
6.25 cubic foot box tuned to 32 hz
DB Linc 200 Amp H/O ALT
1/0 BIG III</div>
Def sounds like an O2 sensor, but before you go spending the money on new O2 sensors, take each one out and spray them off good with brake cleaner, it will clean all the carbon build up off, then put them back in and see if the light stays off, if it does, problem solved
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
thats just a bandaid, it'll stop it for a bit then screw up again. get it done right the first time
  • Who's Online   0 Members, 0 Anonymous, 1546 Guests (See full list)
