okay well i want to build of part of where my back seats were so its level with my cargo spot in my blazer i was thinking that 1/2 " MDF wood could hold my like 10" of my box and then ican build from there what doyou think?
You worded this terribly and I really can't understand exactly what you're asking... Also curious why this is in the off topic section.
Pioneer AVIC-N2
LMAO x2
can you go into a little more detail?
Roseville, CA
yeah sorry lolz xD was playing MW2 and was kinda just typing but basicaly what i did was i took out my back seats from my blazer its two door, so what i want to do it build that spot where the seats were so that it is flat with where the cargo spot is . so its all level. I was thinking of useing 1/2" MDF and some 2x4 for the support leggs. i just was wondering if i put my box on the 1/2" mdf if it will bend? if you get that. i mean it isnt fullying all the box just the back of it b.c the cargo spot isnt that big for air space.
As long as it is properly supported underneath and the MDF is anchored to the 2x4s(or whatever u end up using) then you shouldn't have any issues.
Pioneer AVIC-N2
alright thanks i plan on doing 2x4 for legs then screwing a support to each leg from eachother. ill get pics tom
Sounds a little odd but just do a mock up tomorrow and before u put it in place definitely post sum pics. Also how are the bottom pieces going to be anchored to the floor??
Pioneer AVIC-N2
i have pics up in my build post ill do a fast post right after this of the link but there is the bolts from were the seats were screwd down to and i was gona try and work somthing with that,
